Tastverh. Ladedruckregelventil | Posts 16+
Go to page: Previous  1, 2
Mc_Givertechnik
2010 Volkswagen T5
Post07-07-2004, 20:07    Subject: Quote
Hello!
I seem to be too incompetent to create a graph from the log file. Please, please, provide some assistance.
I just completed another extensive test drive and would like to analyze the results.
Test drive with a new boost pressure control valve and a new mass airflow sensor. The charge air cooler was checked for leaks, the vacuum hoses were inspected, and everything is okay.
Hi everyone,
Peter.
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 15-09-2026, 5:20.
Mc_Givertechnik
2010 Volkswagen T5
Post08-07-2004, 6:30    Subject: Quote
Okay, I finally managed it. Here's the boost pressure while accelerating up to fourth gear, going uphill.
http://gallery.t4forum.de/data/media/3/Grafik_Ladedruck.jpg
And here is the corresponding duty cycle of the boost pressure control valve.
http://gallery.t4forum.de/data/media/3/Grafik_Tastverhltnis.jpg
Translated on 15-09-2026, 5:21.
Post08-07-2004, 7:41    Subject: Quote
Hm.
Your tractor is achieving the desired pressure very well. It's nice to see the slight overshoots.
That's fine! (I would say)
Mc_Givertechnik
2010 Volkswagen T5
Post08-07-2004, 8:56    Subject: Quote
Hmm, yes, according to VAG COM, but the manual display shows something different. Now the question is, who is giving the wrong reading here? My boost pressure gauge or the sensor?
Okay, I'm going to remove the pressure sensor for the turbocharger and test it with a precise gauge. If it shows the correct pressure, then the sensor is likely faulty and sending incorrect, high values to the engine control unit. My tractor is producing a lot of soot.
Regards, Peter.
Translated on 15-09-2026, 5:22.
Post08-07-2004, 9:14    Subject: Quote
Ah, now I understand.
Does your engine have the sensor integrated into the engine control unit (like the 1Z) or is it located externally (like in the G4 TDIs)?
If it's the external one, I would just replace it.
Translated on 15-09-2026, 5:23.
Mc_Givertechnik
2010 Volkswagen T5
Post08-07-2004, 9:17    Subject: Quote
I was just reading Ulf's post about air density. Now I'm also wondering where I should be taking my measurements. The boost pressure sensor is screwed into a pipe after the intercooler (in my case, the large one from the 111kW TDI). However, the boost pressure gauge is connected directly to the turbo, at the outlet where the solenoid valve is also located. That seemed like the most appropriate place to me, because that's where I can see directly if the turbo is being overworked. That's also the reason why I'm so skeptical about the value shown by the boost pressure sensor, or my boost pressure gauge. Directly at the turbo, the pressure should be higher than it is just before the intake manifold, because there should be pressure losses along the way, resulting in a slightly lower boost pressure reaching that point. How much of a difference can it be?
Hi Peter,
Translated on 15-09-2026, 5:24.
Mc_Givertechnik
2010 Volkswagen T5
Post08-07-2004, 9:18    Subject: Quote
Is ein externer Kobisensor, also Ladedruck und Ladelufttemperatur. Der Sensor, phu, hab gerade nach dem Preis gefragt, kostet satte € 90.- exkl. Ust. Einfach so mal tauschen? Mein Ersatzteilspezialist hat mir aber angeboten, ihn testweise ein zu bauen und dann wieder zurück zu bringen, fals es nichts gebracht hat. LeIt's a test!
Regards, Peter.
Translated on 15-09-2026, 5:25.
No new posts Boost Valve: Control & Regulation Diesel Engine Technology
No new posts Boost Control Valve Airflow Ratio Diesel Engine Technology
No new posts Wastegate, boost control valve Diesel Engine Technology
