Power loss 66kW Golf 4 TDI
Fred K
Post23-07-2004, 15:15    Subject: Power loss 66kW Golf 4 TDI Quote
'I'm having the following problem with my Golf 4, 66kW.'
which sometimes causes the performance to collapse.
'So, I'm driving normally, I release the accelerator, and then I experience a loss of power.'
As soon as I turn off the ignition, the car starts moving at a normal speed.
Performance ongoing.
Does anyone have any advice?
Translated on 07-07-2026, 16:48.
Post23-07-2004, 15:18    Subject: Power loss 66kW Golf 4 TDI Quote
Hi Fred,
Unfortunately, you haven't provided enough information for me to give a more helpful answer than "something is probably wrong."
- What type of 66kW TDI engine is it (AGR or ALH)? (This should be stated in the service booklet).
- Are any lights flashing on the dashboard?
- Have you ever had any error codes read? (A good workshop usually doesn't charge for that, and you can put 5 euros in their coffee jar icon_smile.gif).
Based on your questions, I think you probably can't do much on your own. Or would "then check the VTG clearance" mean something to you?
If you know more, we can help you further (beyond this point).
Translated on 07-07-2026, 16:52.
Fred K
Post23-07-2004, 15:29    Subject: Power loss 66kW Golf 4 TDI Quote
- is a 66kW EGR valve.
- nothing is blinking.
- Error codes are being read continuously, but nothing is stored in the error memory.
VTG on a 66kW TDI? You have to show that to me...
VG,
Fred.
G2 TD 07/87 394,380 km
Translated on 07-07-2026, 16:53.
Marco
Post23-07-2004, 15:40    Subject: Power loss 66kW Golf 4 TDI Quote
ALH!
Translated on 07-07-2026, 16:54.
Post23-07-2004, 15:57    Subject: Power loss 66kW Golf 4 TDI Quote
@ Fred
Okay, if you can read the data, then log it while you're triggering the error.
"So, I found a faulty mass airflow sensor (MAF), which was reducing the fuel injection amount to almost zero, causing the car to stall repeatedly - and there were no error codes stored."
Probably you have strange boost pressure or air mass readings, which is why the engine isn't pulling properly... (just a guess).
Greetings.
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post23-07-2004, 16:05    Subject: Power loss 66kW Golf 4 TDI Quote
I'm just wondering right now, what Ulf is putting so much effort into with those technical articles... icon_question.gif icon_twisted.gif It really shouldn't be that difficult to understand...
Translated on 07-07-2026, 16:55.
Julian
Post23-07-2004, 16:18    Subject: Power loss 66kW Golf 4 TDI Quote
It seems some users are already finding it too hot today, so their brains might be going into standby mode, right?
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
I'm sorry, but I cannot access external websites or specific files online, including the URL you provided. Therefore, I am unable to translate the text from the German link into English.
Translated on 07-07-2026, 16:56.
No new posts div. Golf 1J TDI and Gasoline, gradual loss of power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1z 2.0 TDI BMM hat Leistungsverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Diagram Analysis: LMM Golf 4, 66kW On-Board Diagnostics (OBD)
No new posts Troubleshooting Volkswagen Golf 6 TDI 66kW (5K1) Diesel Engine Technology
No new posts Durchzugsschwäche 66kW ALH Diesel Engine Technology
No new posts AGR-Verhalten bei ALH 66kW Diesel Engine Technology
