Diesel Vacuum Pump: Reliable & Efficient
millanni
Post27-08-2004, 13:31    Subject: Diesel Vacuum Pump: Reliable & Efficient Quote
I was actually hoping to find tips on biodiesel, specifically regarding the fuel injection pump for a Ford Transit, on dieselschrauber.de. Can anyone help me out with this? I want to adjust the fuel delivery volume.
Ralf
Translated on 03-10-2026, 11:33.
Post27-08-2004, 15:11    Subject: Diesel Vacuum Pump: Reliable & Efficient Quote
You probably won't find much specific information about a Ford Transit here. However, we're happy to help you with your vehicle. Please tell us the year of manufacture and what type of ESP (Electronic Stability Program) it is!
Translated on 03-10-2026, 11:34.
millanni
Post28-08-2004, 9:59    Subject: Diesel Vacuum Pump: Reliable & Efficient Quote
Okay, it's a Bosch fuel pump (casting mark 1997) from a Transit with 70 horsepower, first registered in 1999.
'I've now noticed that the lock nut on the screw for the full throttle adjustment has failed. The stop is now misaligned, full throttle is no longer possible, so I probably don't have a fuel injection problem. What can I do wrong when re-adjusting the full throttle, and how do I determine the exact point for the adjustment?'
Translated on 03-10-2026, 11:35.
