30c-Tuningidee für PD-Motoren | Posts 48+
Go to page: Previous  1, 2, 3, 4
bloeckler
Post07-05-2004, 10:41    Subject: Quote
ulf wrote:
bloeckler wrote:
Persistent high speed above 3500 RPM and failure to reach the specified speed - accompanied by a noticeable power drop from 3750 RPM
That pretty much matches my experiences. However, I had far from a 12% performance surplus according to the DZR.
Was was 3-4° too late set, and reached 4000 RPM on a subsequent test run. The shaking hasn't changed.
bloeckler
Post08-05-2004, 15:41    Subject: Quote
Just for completeness:
http://www.tdipower.de/shop/powerboxes_for_vag_tdi_pump_housing.htm
The connectors offered here are nothing more than a fixed resistor inside a plastic housing, with the connector being blind-molded to the cable.
Proud Price. [/list]
joergs
Post09-05-2004, 7:34    Subject: Quote
@ulf
I'm hearing you say it again: 'Yes, yes, Digitalist!' icon_cool.gif
but I have an idea for your story, since the coolant temperature sensor obviously doesn't provide the 'powerful' performance that one might expect.
How about implementing the entire salad using MC and a digital potentiometer? You would simply need a digital potentiometer that can handle a 30mA current. Assuming that the diesel temperature sensor has 5 or 12V applied and that the STG measures the current, an input-side I-U conversion would also be necessary, as the MC can only evaluate voltages from the ADC. However, this is not the main problem!
Post09-05-2004, 8:08    Subject: Quote
bloeckler wrote:
The connectors offered here are essentially nothing more than a fixed resistor within a plastic housing, with the connector itself being blind-molded to the cable. Is that correct?
There were at least some boxes offered like that.
What's inside is hard to imagine...
@JörgS:
The leakage current in a short circuit is approximately 6.5 mA (5V with a 750 Ohm pull-up resistor).
Of course, it is possible to create a digital fake - but I would rather create a switching threshold for a small relay from the cooling water voltage, which switches a fixed resistor in parallel with the original diesel sensor, than go through such a "huge" effort.
ttns4
Post31-08-2004, 12:19    Subject: Quote
I just had another idea:
At least visually, the NTC sensor fittings for diesel and water in my engine are so similar that they might be interchangeable.
I had already removed the diesel pump - this can still be done with reasonable effort + mess.
But at the water pump icon_evil.gif located at the rear of the engine, the cooling system would run dry.
According to my measurements, the resistance values shift approximately 20°C out of phase - with the water supply having the lower resistance values.
Perhaps, one could simply replace the diesel injector with a water injector (if they are the same size) and thus have a very inconspicuous modification, without losing the ability to adjust the amount via diesel temperature.
(However, one would hardly get a watering can for 30 cents icon_sad.gif)
The donors, which I mean, have a 2-pole connection, 'front' a stepped metal cap and sit in a rubber O-ring, which protects them from water/ Diesel pipe system sealed.
They are secured against sliding using a U-shaped metal clip on the cable side.
If someone has access to such devices, they might want to check if they actually have the same dimensions - at least the electrical connection or the cable-side connectors look completely identical.
Approximate resistance values at 0 / 10 / 20°C:
Diesel: 15 kOhm / 10 kOhm / 6 kOhm
Water: 6 kOhm / 3.9 kOhm / 2.6 kOhm
@ Ulf: Could you possibly provide me with the number for the water temperature sensor? Hoping it fits in the AJM as well.
It's unbelievable: The workshop can't find the Diesel & the Water Feeder 2-pole!
I'll be in touch soon!! Or is there another option?
They are even offering to sell the complete piping systems.
Greetings
Post31-08-2004, 12:57    Subject: Quote
ttns4 wrote:
@ Ulf: Could you possibly give me the number for the water temperature? Do givers give?
Now appears in the 10c article.
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts PD Motor Performance: Optimization & Tuning Diesel Engine Technology
No new posts Engine Swap: BMW E2 CAN Engines On-Board Diagnostics (OBD)
No new posts Auxiliary Heater for PD Engines Diesel Engine Technology
No new posts Differences V.A.G. Engines AFN, AHH, AHU Diesel Engine Technology
