1. ZR-Wechsle (AHF-TDI): WaPu auch wechseln?! | Posts 16+
Go to page: Previous  1, 2
Yankee
Post22-09-2004, 7:13    Subject: Quote
What did you pay for it?
Approximately 200 tuxedos, but I think the WAPU was included. I need to check that more closely...
Translated on 16-08-2026, 20:53.
WarLord
Post22-09-2004, 20:54    Subject: Quote
Which types of medical devices are driven by a vacuum pump via a rotary joint?
'This applies to almost all TDIs that are newer than the 1Z model. I think it's terrible, but what can you do about it? Some of the 5-cylinder engines in the T4 have also had a few belts fail due to the water pump,' (as someone wrote in another forum).
Best regards, WarLord.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Systematic approach for identifying defects. WaPu 1.9 TDI... Diesel Engine Technology
No new posts Needle Valve: Does it also apply? Diesel Engine Technology
No new posts AGR Problems in the USA? Diesel Engine Technology
No new posts Diode Trick: Works with AHU Units Too? Diesel Engine Technology
