Connections to Gaspoti?
In some wiring diagrams, you can find Gaspotis with two switches operating in sync, which are connected to the control unit via T68. In other cases, these switches are connected to...
F 60 or F8 apparently operate in opposite directions, and strangely enough, in some wiring diagrams, the switching contact that leads to T 6a/4 is labeled as a "kick-down" switch, while in others it is labeled as an "idle" switch!
Does anyone have experience with this and have accurate information about it?
and Thank you
hammets
Translated on 29-08-2026, 18:26.
