Spritzbeginn einstellen bei Audi, wie teuer ? | Posts 16+
Go to page: Previous  1, 2
Post24-09-2004, 19:47    Subject: Quote
christians wrote:
On the other hand, the "angle window at 5 instead of 4 cylinders is smaller, so that the same movement of the fuel injector adjuster should achieve a greater change in the timing point."
No: 3° adjustment in the pump is always 6°KW, regardless of how many cylinders the thing feeds.
Honk
Post02-10-2004, 17:27    Subject: Quote
Hello
I had the values read out from the VAG system: Default setting: 52 at 125, increased idle speed: 31 at 125.
Is this good or not?
Greetings
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Issue with starting the spray gun, model VP37 Diesel Engine Technology
No new posts Adjustable Injection Start: Not Configurable Diesel Engine Technology
No new posts Injection start cannot be adjusted on the 1Z Upload
No new posts Is This BMW 3 Series Too Expensive? Diesel Engine Technology
