Matschke Guest
28-09-2004, 15:28 Subject: Fuel injectors for 130 PD? |
Hello!
Ich habe eine Frage an Euch. Mein Tuner hier in Polen hat einen VW Lupo 1.9 TDI mi ARL Motor gebaut. Das Auto hat nach noch vielen anderen Veraenderungen laut Pruefstand mit einem leichten Chip 202 PS. Wir wollen aber weitergehen und haben irgendwo mal im Internet gelesen, dass es eine Firma in Deutschland gibt, die die Pumpeduesen verbessert und tunt, damit sollen weitere Leistungszuwaechse moeglich sein. Has anyone heard anything about it? I would be grateful for any information.
The vehicle was originally a Lupo 3L, weighs just under 850 kg, and officially runs the quarter mile in 13.65 seconds (a Polish record for diesel vehicles) with a 0-100 km/h acceleration time of 5.3 seconds.
Thank you in advance for your help.
Best regards.
Matschke.
Translated on 20-07-2026, 14:17.
28-09-2004, 21:25 Subject: Re: Fuel injectors for 130 PD? |
Matschke wrote: | | There's a company in Germany that improves and tunes pump injectors, | which should enable further performance gains. Has anyone heard anything about them? Quote: |
Unfortunately, no, but:
| The vehicle was originally a Lupo 3L, weighs just under 850kg, officially runs the quarter mile in 13.65 seconds (a Polish record for diesel vehicles), and accelerates from 0 to 100 km/h in 5.3 seconds.
GEEEEIIIILLLLL
Why doesn't anyone build something like this here?  } Gruß Ulf
Translated on 20-07-2026, 14:19.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
28-09-2004, 21:33 Subject: Fuel injectors for 130 PD? |
Why did I only know that you would be into it  ? Gruß
Translated on 20-07-2026, 14:20.
Profile PM Garage |
MONCHI Guest
29-09-2004, 10:09 Subject: Fuel injectors for 130 PD? |
improves and tunes the pump nozzles
......I knew that I was only driving a slow tractor!!
'That's a really cool car, what kind of transmission does it have? ...Including the 6th gear?'
.....what is the top speed?? ........GOIL, 260 KMH in a Lupo with 165 size wide tires  .
Greetings,
Cheers,
Warmly,
Sincerely,
(or simply)
Hey,
Love, (if appropriate)
XOXO, (if appropriate)
Monchi.
Translated on 20-07-2026, 14:21.
Matschke Guest
29-09-2004, 10:19 Subject: Fuel injectors for 130 PD? |
The transmission is a 6-speed from the ARL engine. We have no idea what the top speed is; we haven't tested it.
Translated on 20-07-2026, 14:22.
29-09-2004, 11:59 Subject: Fuel injectors for 130 PD? |
Are there any options in the "Speed" category for size W  ? Gruß
Translated on 20-07-2026, 14:23.
Profile PM Garage |
Matschke Guest
29-09-2004, 12:10 Subject: Fuel injectors for 130 PD? |
The vehicle doesn't have 165 tires fitted; it has 195/45 R 15 tires, and for racing, thinner tires are used on the rear.
matthiasTDI96 Profi-Schrauber
29-09-2004, 19:00 Subject: Fuel injectors for 130 PD? |
Hey, did you also do any brake tuning? It looks like you've managed to save weight while still staying true to the original design.
Matschke Guest
29-09-2004, 19:04 Subject: Fuel injectors for 130 PD? |
The brakes have been improved; the front now features 288mm brake discs.
We also implemented weight reduction measures; inside, only two seats are installed, and for racing, only the driver's seat is used.
Translated on 20-07-2026, 14:24.
Calvin Guest
04-10-2004, 9:20 Subject: Fuel injectors for 130 PD? |
Where is the thread with all those pictures?
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2401 Karma: +438 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
04-10-2004, 13:49 Subject: Fuel injectors for 130 PD? |
Calvin wrote: | | Where is the thread with all those pictures? |
Removed by the administrator due to excessive self-promotion and an uncooperative user.
Profile PM Garage |
