AFN Chip: What it is and how it works
RazsmithII
Post05-10-2004, 22:28    Subject: AFN Chip: What it is and how it works Quote
Hello TDI enthusiasts,
I received an Oettinger chip as a gift for my AFN.
However, this chip comes from an A4 AFN, while I own a G3 AFN myself.
Sollte es da Probleme geben bzgl. Checksum or similar?
The engine control unit (ECU) should be the same (021GN).
Best regards, Nico.
Translated on 05-08-2026, 4:30.
Post06-10-2004, 7:24    Subject: AFN Chip: What it is and how it works Quote
As long as the engine control units have the exact same part number, there's no problem.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 05-08-2026, 4:31.
RazsmithII
Post06-10-2004, 21:17    Subject: AFN Chip: What it is and how it works Quote
Do only the part numbers need to be identical, or also the two letters after the number?
If I still install the chip, and if the letters are different, I assume that the checksum will be different, and the engine won't start at all, but nothing will break in the control unit... did I learn that correctly from the forum? icon_eek.gif
Translated on 05-08-2026, 4:32.
Post06-10-2004, 21:55    Subject: AFN Chip: What it is and how it works Quote
RazsmithII wrote:
Only the
part numbers
need to be identical, or do the two letters after the number also have to match?icon_eek.gif
Also, the letters following the number are also important. However, there are usually several different configurations (letter combinations) that can run on the same control unit. On the other hand, there are often many more configurations that don't work.
Falls ich den Chip dennoch einbaue, falls die Buchstaben anders sind, gehe ich davon aus, dass die Checksumme unterschiedlich ist und sich der Motor gar nicht starten läßt, jedoch aber am Steuergerät nichts kaputt geht.....habe ich da richtig im Forum gelernt.. ?? }} Ja, hast du. AlLet's try it out...
Sure.
Translated on 05-08-2026, 4:33.
RazsmithII
Post06-10-2004, 22:08    Subject: AFN Chip: What it is and how it works Quote
Wonderful... then I'll give it a try.
'I'll start by soldering in the socket pins (if they haven't already been installed, which I assume isn't the case).'
not going out...?!)
and then, if necessary, I can always still 'back out' icon_cool.gif.
Thank you for the quick help!
P.S. I have just 'fully and specifically' determined that the last letters definitely differ: GIII: ...021JG; A4: ...021GN. icon_rolleyes.gif
What is your estimated probability that it will work?
not ?? If there's virtually no chance, I will definitely not do it from the beginning, because it's not worth the effort for me. icon_question.gif icon_question.gif
Translated on 05-08-2026, 4:35.
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts Chip Tuning 115 PS - Performance Upgrade Diesel Engine Technology
No new posts AFN Timing Belt & Chip Replacement Diesel Engine Technology
No new posts TÜV and Chip: What You Need to Know Diesel Engine Technology
No new posts new chip Diesel Engine Technology
