Boost Valve Airflow Ratio Explained
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post10-10-2004, 20:30    Subject: Boost Valve Airflow Ratio Explained Quote
I've once again used VAG-Com to measure my values regarding boost pressure, mass airflow sensor (MAF), etc., and I noticed that the actual boost pressure settles about 0.1 bar below the target boost pressure after an overshoot (up to 2090 mbar). The boost pressure is lacking from approximately 2400 - 4000 RPM. Does this indicate a faulty boost pressure control valve icon_question.gif? Because the duty cycle seems to be stuck around 55%. There should still be enough room in the duty cycle range to adjust the boost pressure icon_question.gif.
The fact that my large language model is slowly starting to fail again probably has nothing to do with this, right?
Here's a visual representation.
http://img16.exs.cx/img16/1060/neu-5.jpg
http://img16.exs.cx/img16/1876/neu-6.jpg
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Translated on 12-08-2026, 14:05.
Back to top Profile PM Email
Post10-10-2004, 20:41    Subject: Boost Valve Airflow Ratio Explained Quote
The air mass target value should be 850 mg/stroke, right? 800 is less than 850...
It's possible that the turbocharger pressure is behaving "strangely" due to restrictions related to emissions regulations.
Just do another test drive with the "mass airflow sensor replacement diode" installed, but with the EGR system disconnected (outside of public roads due to potential loss of approval).
Translated on 12-08-2026, 14:08.
Post10-10-2004, 20:58    Subject: Valve Duty Cycle: Explained & Optimized Quote
wbuchi82 wrote:
The boost pressure is missing from approximately 2400 - 4000 RPM. Does this indicate a faulty wastegate control valve? icon_question.gif The duty cycle seems to be stuck around 55%. There's still plenty of room in the duty cycle range to adjust the boost pressure. icon_question.gif
Take a look at this:
Your symptoms are fundamentally similar.
If the boost pressure is not reached with the normal duty cycle, there can be several other causes besides the VTG vane -> see specialized article icon_wink.gif.
Translated on 12-08-2026, 14:09.
wbuchi82
Post11-10-2004, 7:03    Subject: Boost Valve Airflow Ratio Explained Quote
Thank you for the answers!
I'll still try experimenting with the mass airflow sensor. Since my tractor tends to produce a little soot even when running at full throttle, it suggests that it might be lacking some air. Also, I'm about one second short of the optimal value for the traction test (around 7.2 seconds measured). But first, I'll focus on getting the mass airflow sensor working properly.
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Translated on 12-08-2026, 14:11.
No new posts Golf 4: Location of the boost valve Diesel Engine Technology
No new posts Boost Control Valve Airflow Ratio Diesel Engine Technology
No new posts Key Ratio: Clarification Diesel Engine Technology
