Cold start problem 2.5 TDI V6
Gordon501
Post11-10-2004, 15:37    Subject: Cold start problem 2.5 TDI V6 Quote
The diesel fuel pump in my A4 Avant 2.5 TDI (manufactured in 12/99, 187,000 km) needs to be replaced.
installed from a Passat with the same engine. 'Previously, the pump was...'
at the Bosch service center for overhaul and adjustment.
Since then, the vehicle only starts after several attempts, especially if it has been idle for a while.
more than 10 hours, for example, in the morning.
The copper seals on both sides of the pump were replaced. The error.
The memory shows no data. This error didn't occur on the Passat before.
Does anyone have any ideas about where we could look?
Post11-10-2004, 15:48    Subject: Cold start problem 2.5 TDI V6 Quote
What is the purpose of the search function and the error database?
/viewtopic.php?t=3687&highlight=starting problems
No new posts Kaltstartproblem 2.5 TDI Diesel Engine Technology
No new posts Cold start problem PD AUY Diesel Engine Technology
No new posts 1.9 TDI ALE Kaltstartproblem Diesel Engine Technology
No new posts Cold Start Problem: Strange Issue? Diesel Engine Technology
