Ultrasonic Cleaning: Injectors for 1Z Engines?
MWeid
Post16-10-2004, 11:25    Subject: Ultrasonic Cleaning: Injectors for 1Z Engines? Quote
Hello diesel mechanics!
First, here are the details of my car:
- Volkswagen Golf III 1Z, 196,000 km, manufactured in 1995.
- No tuning.
- Negligible soot.
- No loss of performance.
- No increased fuel consumption.
- No abnormal oil consumption.
- No starting problems.
Yesterday I asked my trusted mechanic if he could replace the EGR valve for me. He told me that I should save the €300 for now and only replace the injectors if problems arise. As I said, my car is running perfectly fine so far, and I was just thinking of replacing the EGR valve out of precaution.
He told me that he could disassemble the nozzles and clean them in an ultrasonic cleaning device, and that he had already done so with other components.
Now my question: Is it useful, advisable, good (or perhaps even bad) to clean the fuel injectors with an ultrasonic cleaning device?
Since the nozzles are already being removed, I'll also have them checked by the Bosch service department.
Thank you very much and have a nice weekend.
Mathias.
Translated on 05-08-2026, 16:15.
Albrecht
Post16-10-2004, 18:08    Subject: Ultrasonic Cleaning: Injectors for 1Z Engines? Quote
"The ultrasonic cleaner won't damage the nozzles; I've used it myself before. However, I didn't notice any difference afterward. I think the issue of deposits in the nozzles is often overblown. In any case, cleaning won't improve a deteriorating spray pattern caused by abrasive wear."
I would advise you to follow your mechanic's advice and not touch anything as long as the car is running properly.
Albrecht.
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
08/08-07/15 A6 (C5) Av. quattro 6-Gg., EZ 10/02, AKE 189-265Tkm (Kolbenriss)
07/15-09/17 A6 (C6) Av. qu. 6-Gg. 3.0 TDI, CDYC, EZ 05/11 180-210Tkm (verkauft)
08/17-11/17 A6 (C7) Av. qu 3.0 TDI comp.(leasing)
seit 2018 Skoda Roomster 1.6 TDI 5-Gg.
Translated on 05-08-2026, 16:18.
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts ASV Injectors for ALH Engines Diesel Engine Technology
No new posts Fuel Injectors AKN - Buy Now! On-Board Diagnostics (OBD)
No new posts AEY Injectors: High Quality & Performance Diesel Engine Technology
No new posts TDI Injectors: AFN to 1Z Conversion Guide Diesel Engine Technology
