Gesammelte Bilder vom 1Z AGR, Saugstutzen und Kruemmer | Posts 16+
Go to page: Previous  1, 2
chrisgtd1
Post15-10-2004, 18:48    Subject: Quote
@martin
hello there.
I test drove the car today.
and my acquaintance, who had also driven the car before, said that the car...
Before I cleaned the AGV, it was in worse condition.
It's possible that closing the AGV (automatic guided vehicle) could cause the engine to lose power.
because anything else is impossible; I've put everything back together exactly as it was before.
Is that just the drive for leaving it running?
Does anyone have another suggestion?
Translated on 07-08-2026, 1:19.
Zoidberg
Post16-10-2004, 16:59    Subject: Quote
dieselmartin wrote:
Price range: ????
I soaked this part in diesel for 2 days - except for the seals and screws, nothing else is new
hehe, okay - it looked so new in the pictures icon_cool.gif. How did you get all that grime out of it? Did you rinse it after the diesel bath, use a brush, or something else? What's the consistency of that stuff after being soaked in diesel for 2 days?
Bye.
Christoph.
Translated on 07-08-2026, 1:20.
Post17-10-2004, 10:45    Subject: Quote
@zoidberg
I actually described the cleaning process in the first post of my cleaning thread.
for 3 EUR, I went inside the washing machine and used a pressure washer (be careful, it spits back icon_wink.gif).
Then I spent two days driving around with a broken breast (likely referring to a car).
The grime cannot be removed simply by the presence of diesel; it won't dissolve or wash away. You need to use your fingers and brushes to work on it.
@chrisViewing profile: chris
Do you have a new throttle body installed? The black part with the four intake openings?
It absolutely has to be replaced.
Is everything alright? / Is everything okay? / Is everything sealed?
You shouldn't rely solely on the driving feel; do you have any data showing the Z-axis values before and after closing [something]?
Translated on 07-08-2026, 1:22.
chrisgtd1
Post20-10-2004, 18:20    Subject: Quote
@martin
hello martin
I took the gasket again, but this time I applied sealant to it. The whole thing is now sealed.
'Unfortunately, at the exact moment I was cleaning it, my LMM (likely referring to a mass airflow sensor) failed.'
and then I thought it might be related to the hard drive.
Okay, I'll order the mass airflow sensor on eBay now and then we'll see how it goes.
Martin, thank you, you're a really good person.
Sure, here's the translation:
'Best regards, Chris' or 'Greetings, Chris'
Translated on 07-08-2026, 1:24.
No new posts Collected Uncertainties in the Permeability Test Diesel Engine Technology
No new posts 1Z Kruemmer Turbo Mounting - For LZ Models Diesel Engine Technology
No new posts Plastic Suction Nozzles: Buy Online Now Diesel Engine Technology
No new posts Vacuum Nozzle 1Z - Incorrect U-Washers? Diesel Engine Technology
