Fuel Injector Start: Automatic Adjustment
frebert
Post26-10-2004, 6:51    Subject: Fuel Injector Start: Automatic Adjustment Quote
Morning, Foriker.
"I had the timing belt replaced about 4,000 km ago on my 81 kW AFN engine. Afterwards, I checked the fuel injection timing using a TDI-checker. It was slightly earlier than the ideal setting."
Now, after approximately 4000 km, I checked again and found that the injection start timing is exactly on the "target" line.
Is this normal? (Belt expansion)
Has anyone ever had this experience before?
Okay, here's the translation:
Thank you.
Greetings.
Frebert.
1,9 l AFN mit Schick Wasser LLK im T3
Translated on 30-10-2026, 8:04.
Thomas Falke
Post26-10-2004, 11:39    Subject: Fuel Injector Start: Automatic Adjustment Quote
Hello, I would say that your timing belt has stretched slightly over time. This can sometimes happen, especially since it's only measured in millimeters.
Thomas Falke.
Translated on 30-10-2026, 8:05.
No new posts Audi A3 8P: Floor Covering Detaching Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do windows open on their own? General Tips
No new posts Long-term consumption display has changed On-Board Diagnostics (OBD)
No new posts The steering angle at the BRS motor does not change Diesel Engine Technology
No new posts Spritzbeginn has changed after 20,000 km, is this normal? Diesel Engine Technology
No new posts Engine Revs Briefly on Its Own? Diesel Engine Technology
