Twin Power Turbo: High-Performance Electricity
Post26-10-2004, 17:11    Subject: Twin Power Turbo: High-Performance Electricity Quote
Hi.
Could it be that the KKK turbocharger from the JX (which is a K24, or is it?) is a twin-scroll turbo, while Garrett doesn't use one in the 1Z?
I was wondering about the strangely bulky exhaust part on the JX and just read something about the twin-stream system.
"Thank you."
Translated on 23-10-2026, 3:56.
Gremlin
Post26-10-2004, 18:38    Subject: Twin Power Turbo: High-Performance Electricity Quote
Hmm... I'm not quite sure I understand what a two-stage loader is.
Just take a look inside... you can see if there are two separate pipelines leading to the turbine.
However, there should also be two exhaust outlets, one connecting 1 and 4, and another connecting 2 and 3.
CU Gremlin.
Translated on 23-10-2026, 3:57.
Post27-10-2004, 6:13    Subject: Twin Power Turbo: High-Performance Electricity Quote
Okay, so the crumple zone definitely involves all four cylinders.
However, they could potentially be "split" again at the turbocharger inlet.
I was just wondering about the thick exhaust manifold, which looked very similar to the one in the BOSCH manual.
Okay, here's the translation:
Thank you.
Translated on 23-10-2026, 3:58.
Gremlin
Post27-10-2004, 8:45    Subject: Twin Power Turbo: High-Performance Electricity Quote
So, the Kruemmer almost definitely connects all 4 cylinders together.
However, they could potentially be 'split' again at the turbocharger inlet.
nope...
If the exhaust manifold combines four cylinders into one, you can no longer install a twin-scroll turbocharger. The purpose of such a manifold is that the two 'halves' are alternately exposed to exhaust gas (pressure), which minimizes the dead volume through the twin-scroll design. This doesn't make much sense for a small four-cylinder engine, but it does for larger six-cylinder engines.
Take a look inside here: http://www.turbos.bwauto.com/de/products/design_turbine.asp
CU Gremlin.
Translated on 23-10-2026, 3:59.
Post27-10-2004, 8:52    Subject: Twin Power Turbo: High-Performance Electricity Quote
Great, thanks for the link.
Tonight, the turbo will be temporarily glued back on (it's leaking somewhere near the exhaust manifold).
"When we get a new one, I'll take a closer look at the old one."
Translated on 23-10-2026, 4:00.
Post27-10-2004, 8:58    Subject: Twin Power Turbo: High-Performance Electricity Quote
Here's also a nice vintage picture showing it in both positions.
http://www.turbos.bwauto.com/files/library/bwts_library_142_168.pdf
Translated on 23-10-2026, 4:01.
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbo AAZ to Turbo 1Z Conversion Guide Diesel Engine Technology
No new posts 1.9 TDI PD ASZ Oil on Turbo Diesel Engine Technology
No new posts VGT Turbo for AHU Engine Diesel Engine Technology
This topic is locked, you cannot edit or reply. AFN Turbocharger for AHU Engine Diesel Engine Technology
