Boost Sensor Signal: Causes and Solutions
Marzocchi
Post28-10-2004, 13:12    Subject: Boost Sensor Signal: Causes and Solutions Quote
After a fruitless search, I'm trying here.
Does anyone know how to successfully manipulate the boost pressure sensor signal on an ALH engine to achieve approximately 0.2 bar more boost pressure?
I appreciate every post. Best regards, Bernd.
Golf IV - ALH - Erstzulassung 9/99
Translated on 18-10-2026, 7:35.
Post28-10-2004, 13:14    Subject: Boost Sensor Signal: Causes and Solutions Quote
The 10 Cent Tuning expert article knows this.
Marzocchi
Post28-10-2004, 14:01    Subject: Boost Sensor Signal: Causes and Solutions Quote
Everything is described in detail.
In the 10cent article, I wouldn't have expected that - but (upon further reflection), it wasn't entirely surprising.
Translated on 18-10-2026, 7:36.
Marzocchi
Post28-10-2004, 14:05    Subject: Boost Sensor Signal: Causes and Solutions Quote
It would be interesting to know how to proceed with the ALH.
My sensor is located under the windshield washer reservoir (near the coolant expansion tank). I was thinking I could simply solder a resistor between the wires coming from the combined temperature/pressure sensor. Is that not the correct approach?
