Module Codes Online: Find Them Here!
joe
Post06-11-2004, 19:21    Subject: Module Codes Online: Find Them Here! Quote
I mistakenly overwrote my ABS module code with an incorrect value and didn't save the original. Where can I find the original code, or who can help me?
Audi A6, manufactured in July 2000, Quattro, 2.5 TDI, 132 kW.
VAG part number for the ABS control unit: 8D0 907 389 E.
Translated on 11-10-2026, 15:33.
edazer
Post06-11-2004, 21:29    Subject: Module Codes Online: Find Them Here! Quote
Which type of transmission is installed?
Does he have ESP?
edz
Translated on 11-10-2026, 15:34.
Uwe@Ross-Tech
Post06-11-2004, 21:34    Subject: Module Codes Online: Find Them Here! Quote
Starting with version 404.0, you can find the file 'CodingLog.txt' in the debug directory, which contains all the coding changes you have made (including the original values). icon_smile.gif
-Uwe-
joe
Post07-11-2004, 8:47    Subject: Module Codes Online: Find Them Here! Quote
Hello edazer,
Yes, it has ESP and Tiptronic.
Hello UWE,
I still have the VW tool from DRV. I think it's time for you to buy the latest version of VAG-COM.
Thank you!
Translated on 11-10-2026, 15:35.
edazer
Post07-11-2004, 14:20    Subject: Module Codes Online: Find Them Here! Quote
6-cylinder diesel / Quattro (all-wheel drive) / automatic transmission.
Login 07557
Coding: 06257
assuming it's not an Allroad.
best regards
edz
Translated on 11-10-2026, 15:36.
joe
Post07-11-2004, 15:16    Subject: Module Codes Online: Find Them Here! Quote
Thank you, edazer. This forum is where the experts are.
I've just come to the same conclusion.
07557
from left to right:
I don't know about 07.
5 Brake FN3
5 6-cylinder TDI.
7 Tiptronic.
Here, I've also found something.
http://1.8t.org/~quattroman/Audi%20B5%2097-2001/Suspension%20Wheel%20and%20Brakes/Brakes/Brake%20System%20OBD/01-217%20ESP%20Bosch%205.3.pdf
Can you explain why the first two digits are different on pages 24 and 26?
What are the values for the login code and the code itself?
'With my old VW tool (the predecessor to VAG-COM), I can change the code and it displays the change, but it doesn't save the new setting.'
I guess I'll have to find a VAG 1551.
Translated on 11-10-2026, 15:37.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OBD2 Adapter for VW Passat 3C Diagnostics On-Board Diagnostics (OBD)
No new posts How to Clear Bluetooth Module Memory Electrical Systems, Vehicle Electronics, Multimedia
No new posts 1.6 TDI AGR module cannot be programmed Diesel Engine Technology
No new posts Online Parts Catalog: Find Parts Fast Diesel Engine Technology
