Hi everyone,
I've Googled, searched the forum, and I'm still stuck with my problem.
Car: 1J, AXR, Pacific special edition, manufactured in 2004, model year 2005.
I would like to make some adjustments to the comfort control unit and parking distance control using VAG-Com (disable the flashing lights when unlocking and reduce the volume of the parking sensors).
The location of the control units is known, and the channels that need to be adjusted are also identified.
Problem: The login code '12233' only works for the engine control unit. I am therefore looking for a 7-digit login code with WSC, importer number, date, and time. The customer service representative is being unhelpful.
Does anyone happen to have a corresponding code, or does anyone have a program that generates these codes?
Sure, here's the translation:
'Thank you in advance.'
'Micha'
Translated on 25-10-2026, 21:56.
