PostPolo Verbraucht viel und ruckelt | Posts 16+
Go to page: Previous  1, 2
Diesel_Rudi
Post02-12-2004, 16:53    Subject: Quote
Let's move away from heating oil for a moment... Back to the question. I don't have a crystal ball, but my guess is that the air bubbles are rising from the pump into the line. Let's check it out! The shaft seal might be worn or damaged.
Best regards!
Translated on 20-08-2026, 1:04.
Andi84
Post02-12-2004, 23:13    Subject: Quote
So, the stain under the car was actually motor oil mixed with rainwater. It's due to a faulty oil pressure sensor (is that the technical term?).
I also thought about the possibility of a leak in the ESP system, but how could something get into the fuel line before the ESP (while the engine is running)?
What is the function of the white plastic part that sits on top of the fuel filter and through which the return hose runs? Is it an automatic air vent for the filter? Does it contain a type of check valve to allow air out but prevent air from entering?
From below, the vehicle is clean and dry along the fuel lines.
Regarding the cold start accelerator, where can I find any tips on adjusting the ESP (Electronic Spark Advance)? The screws indicate that someone has likely tampered with the settings before.
And one more thing, although it's a post-polo car, it's still in very good condition and, in my opinion, hasn't been abused. It also doesn't have any dents or scratches. The performance is fully there icon_cool.gif. It starts up really well too. So I'm not worried about the engine itself. A 1.9L engine with 64 'killer' horsepower shouldn't be easily damaged.
Translated on 20-08-2026, 1:06.
Post02-12-2004, 23:52    Subject: Quote
If you're serious about using heating oil, there's nothing more I can do to help you. If you genuinely don't know that using it in vehicles is a punishable offense, let me tell you that even if you fill up with regular diesel now, the presence of heating oil can still be detected for a very long time.
Translated on 20-08-2026, 1:08.
Olaf
Post03-12-2004, 11:38    Subject: Quote
1.9 SD with 64 horsepower!
I can't believe it. They're selling this engine in new cars in Argentina. Before, they always had the 90 hp VP-TDIs. Those didn't sell well (or the workshops couldn't handle them), and then VW dug up this old 1.9 SD engine. I honestly didn't think they would dare to sell that ancient thing. I thought it was more likely a special, "new" low-maintenance design for Latin America.
Well, you never stop learning...
Olaf.
Translated on 20-08-2026, 1:09.
Back to top Profile PM Email
Post03-12-2004, 20:54    Subject: Quote
Andi84 wrote:
What is the function of the white plastic part that sits on top of the fuel filter and through which the return hose passes?
This plastic part is used to regulate the temperature of the return fuel line. Up to a certain temperature, the return fuel (warm diesel) flows into the filter and is then immediately made available to the pump again. Above a certain temperature, the fuel flows directly back into the tank.
By the way, there have already been cases where this part has broken due to aging, causing air to enter the fuel injection system. The problems were probably similar to what you're experiencing.
Translated on 20-08-2026, 1:11.
Andi84
Post05-12-2004, 11:19    Subject: Quote
Hey, thank you very much, Bertil!
Yesterday, I took the part off and tried blowing through it with my mouth to see if there was a valve inside. At a certain pressure, something suddenly shot out from the other end, and it became easier. Unfortunately, it's still shaking this morning. I'm going to buy a new one tomorrow. That would also explain why it only shakes when the engine is cold.
'MFG' stands for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English. It is a common way to end a formal letter or email.
Translated on 20-08-2026, 1:12.
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Too much oil: Causes and solutions Diesel Engine Technology
No new posts BMP consumes too much resources. Diesel Engine Technology
No new posts Golf IV 81 kW ASV consumes too much Diesel Engine Technology
No new posts Best German Shepherd Breeders: Find Yours Now! Diesel Engine Technology
