Boost pressure too high after chip tuning?
GRace
Post09-12-2004, 21:05    Subject: Boost pressure too high after chip tuning? Quote
First of all, hello everyone in this forum.
I have only participated in this forum as a reader so far, and I've already read quite a few interesting things.
I would like to ask you a question.
I have an Audi A4 2.5 TDI AKE with 180 horsepower, which has been tuned with a chip to approximately 210 horsepower.
I'm experiencing the following problem: For the past 5 days, when accelerating in 6th gear, I'm experiencing strong vibrations (a rumbling or humming sound) between approximately 1400 and 1800 RPM. In the forum, I read that the problem could be caused by a loose clamp on the exhaust, a tensioner for the timing belt, or one or more EGR valves.
I then performed the recommended measurement using VAGCOM, specifically measuring blocks 13 and 14, which relate to 'idle speed control.' The result in block 13 was approximately +0.18 for all values.
At Block 14.
Cylinder 6 to 2 +0.25.
Cylinder 4 to 2 +0.28.
Zyl 5 to 2 - 0.16
Is the value for cylinder 5 still okay, or does it indicate a defect in the ESD? icon_question.gif
I then took some more measurements icon_rolleyes.gif of the mass airflow sensor, ranging from 780 to 1000.
Okay. Then I thought, 'Hey, why don't you check the boost pressure?'
icon_eek.gif now this is important, I've measured the setpoint versus actual pressure.
Here's what came out:
http://img116.exs.cx/img116/6028/image0012fq.gif
What do you think? Measurement error, or did the tuner exaggerate?
What I also find strange are the enormous pressure spikes of 1.5 bar, the extremely slow build-up of boost pressure, even though it's a V6 TDI (which needs engine speed to drive the turbo), and the fact that the boost pressure remains below the target value, which I find a bit too high.
What do you think? Surely, the boost pressure can't be good for the turbo. icon_sad.gif
I haven't yet checked the VTG struts for proper free movement. A faulty charge pressure control valve could be the cause of the overshoots.
Questions upon questions, I would definitely be very happy to receive one or more answers. icon_wink.gif
Okay, then have a pleasant Thursday evening.
Jan6K
Avatar-Jan6K
Post09-12-2004, 21:13    Subject: Boost pressure too high after chip tuning? Quote
I haven't yet checked the VTG rods for free movement.
You should definitely do that. That's exactly what it looks like to me.
The overshoot itself is normal (in relation to the rest of the curve - my ASV also goes up to 2300, but mine is set to 2000), but if you look at the actual curve, you can see that it increases and decreases in steps, meaning it only adjusts when enough force via the vacuum actuator is built up to overcome the jerky VTG.
Jan.
1Z5 CFHF / AHB H4D
SD16
Post09-12-2004, 21:23    Subject: Boost pressure too high after chip tuning? Quote
Hello.
I find it hard to believe that it has 210 horsepower, because the power output of these V6 TDI engines is limited by the fuel injection pump. The highest power increase I've seen was 18 horsepower.
The vibrations could also be caused by the tuning chip, especially if the torque has been increased too much!
Who tuned it?
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post09-12-2004, 21:34    Subject: Boost pressure too high after chip tuning? Translating...
[Translating...]
Hi!
Hab vor einigen Tagen auch ein Thema reingestellt welches sich mit Überschwingern beschäftigt. Dabei habe ich auch bei einem 90 PS ALH icon_exclaim.gif Überschwinger von 1,5bar geloggt icon_eek.gif (ohne Chiptunig --> Soll Wert liegt bei 0,85bar) ( https://community.dieselschrauber.org/en/viewtopic.php?t=7902 )
Insofern kommen mir diese 1,5bar bei deinem Chipgetunten Motor (Soll Kurve liegt ja auch bei 1,4bar) nicht übertrieben hoch vor. Jedoch kommt mir die Soll-Kurve auch ziemlich hoch vor. Also wenn dein Turbo diese 1,4 bar ständig bringen soll dann würde ich mir schon mal einen neuen auf Lager legen icon_confused.gif
Die Ist-Kurve mit den 2,2bar würde ich eher für den richtigen Wert halten. Jedoch glaube ich auch das es an deiner VTG liegt, warum er den Soll Wert nicht erreicht.
Das dies jedoch mit deinem Brummen oder Vibrieren zu tun hat glaube ich aber nicht.
Die ESD sehen mir auch ganz gut aus. Die Toleranz liegt ja soweit ich weiß be +2/-2 pro Zylinder icon_question.gif
Bemerkst du Leistungsverlust? Oder sonstige Auffälligkeiten im genannten Drehzahlband? Wenn du den Soll Ladedruck jemals erreicht hast, und der Motor jetzt mit ca. 0,2bar weniger als früher mit Frischluft befüllt wird müsstest du ja eigenltich auch einen schlechteren Durchzug bemerken
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Back to top Profile PM Email
GRace
Post09-12-2004, 22:20    Subject: Boost pressure too high after chip tuning? Quote
icon_eek.gif That went by quickly. Thank you for your responses.
@SD16
'The chip is from TCM Tuning, a small company based in Bavaria. I've also read that if the driveshaft isn't perfectly balanced, it can cause vibrations after the chip is installed. I had it done last spring and haven't experienced any problems yet. However, the car isn't driven at full speed on the highway.' Could it be that the lower temperatures in recent days = more oxygen in the air have increased the torque (MAF = up to 1000) and thus exceeded the threshold to trigger the vibrations?
210 horsepower is quite common; most tuners offer that as a standard option. Whether it's ***, Digitec, MTM, or...
Does anyone know what the typical maximum boost pressure is for an AKE engine?
@wbuchi82
I read the thread icon_eek.gif. I wouldn't have thought so either. No, the car otherwise runs normally, with a fuel consumption of around 8 liters. I can't feel any loss of power. The only thing I've noticed in the last few days is that it used to make a slight rattling noise (like the 'Scheinwerferlicht Hintermann' sound) when starting in first gear with full throttle, but it hasn't really done that for the past few days. Is it due to the low temperatures, icon_rolleyes.gif I have no idea. icon_question.gif
Here's another log file: 4. Let the engine idle up to the rev-limiter, then let it coast down to a stop, and then resume normal driving.
http://img65.exs.cx/img65/5553/image0023ri.gif
Uwe
Post10-12-2004, 0:30    Subject: Boost pressure too high after chip tuning? Quote
The 1.9 liter TDI engines I'm familiar with exhibit exactly this effect. They perform noticeably better in low outside temperatures compared to warmer weather. We've discussed this topic quite a bit here before, but without ever pinpointing the exact cause.
Similarly, the 1.9-liter engines with increased torque tend to vibrate around 2,000 RPM, which is more noticeable in the winter but not present in the summer.
Since you received your chip in the spring, you haven't experienced temperatures below freezing yet. I suspect that's the explanation.
Uwe
joe*
Post10-12-2004, 1:43    Subject: Boost pressure too high after chip tuning? Quote
Hi!
90 HP ALH (without chip tuning --> Standard value is 0.85 bar)
Just a small correction: The ALH has a target charging pressure of 0.95 bar.
The charging pressure on your tuned engine is approximately 0.15 bar higher than the standard pressure. Around 4000 RPM, it's about 0.2 bar more.
I don't think these relative values are that bad.
However, I'm afraid I can't tell you how long the turbo will last.
Joe.
SD16
Post10-12-2004, 22:46    Subject: Boost pressure too high after chip tuning? Quote
Try checking the original part for vibrations; that will guarantee it's the right one.
roli752001
Post10-12-2004, 23:04    Subject: Boost pressure too high after chip tuning? Quote
'Then it's probably gone again. With the Quattro and its over 400 Nm of torque, and the low truck-like RPMs, it also vibrates due to tension, which is noticeable even in 3rd gear at 1600 RPM. However, with front-wheel drive, the tires tend to slip.'
GRace
Post11-12-2004, 13:11    Subject: Boost pressure too high after chip tuning? Quote
Hello everyone, thank you very much for your suggestions and answers.
@Uwe
Okay, as I've heard before. Apparently, on the Quattro, the issue is with the driveshaft connected to the rear axle. When the torque is too high, it starts to vibrate, and this vibration builds up until it becomes clearly audible inside the car. At higher speeds, it stabilizes again.
However, there's a problem: I only experience the effect in 6th gear icon_confused.gif. In the fifth [section/area], very slight signs are detectable, while in the remaining passages, there is absolutely nothing.
@joe*
I looked at VAGCOM again, and it says that the boost pressure, in 3rd gear at full load, should be between 1900 and 2300. So, it's probably as you said: a boost pressure increase of approximately 0.1 to 0.15 bar. I hope the turbo can handle it, although the AKE icon_sad.gif is supposedly already at its limit from the factory.
@SD16
Unfortunately, it's 250 km to the tuner. icon_sad.gif It's not a chip or a box, but rather it was modified via OBD, so it's not as simple to revert to the original settings quickly, unfortunately.
@roli752001
icon_eek.gif I haven't managed to get the Quattro to spin its wheels yet, except for in snow, and not even in first gear or in any other icon_wink.gif.
No chance, thanks to the torque-sensing differential. In winter conditions, it's then called 'oversteer' without end, but only until the next turn, because the lateral forces unfortunately remain the same icon_smile.gif.
I'm going to wait until it gets a little warmer outside (we're at -4 degrees Celsius and have had fog for 5 days here in the south) and then I'll check the VTG adjustment and observe the whole thing.
Is there a way to slightly reduce the turbo's boost to decrease the boost pressure and torque in the lower RPM range, in order to check if the problem is related to the driveshaft?
Okay, see you later, thanks to you all.
No new posts Motor dreht hoch nach Warmstart Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ladedruck Vergleich Serie / Chiptuning TDI BKC mit File On-Board Diagnostics (OBD)
No new posts Boost pressure too high On-Board Diagnostics (OBD)
No new posts High Boost Pressure: Causes & Solutions Upload
No new posts High Boost Pressure, ASZ Engine Diesel Engine Technology
