DSP: McDonald's Missed the Deadline
PeterK
Post12-12-2004, 14:40    Subject: DSP: McDonald's Missed the Deadline Quote
Hi there,
I used a self-made adapter (!!) and the locking functions for the closing mechanisms automatically engaged and then disengaged. During this process, I checked the measurement blocks in several control units.
Result: The locking mechanism is working! However, the turn signal could not be unlocked, and he said the group was unavailable.
But the worst part is: the radio forgot that a DSP is installed!
Symptoms: There is absolutely no sound, and when the DSP button is pressed, the radio indicates that DSP is not available.
Can someone tell me how to re-encode/re-pair this?
"By the way, how can I unlock the fader for the rear speakers that were installed later?"
Peter K.
MJ 2002 MCD with DSP.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
aab 78ps und 4 betten, küche, aussendusche
133+ Tkm
Translated on 26-09-2026, 14:31.
Theresias
Post12-12-2004, 18:24    Subject: DSP: McDonald's forgot! Quote
The turn signal couldn't be activated when locked, and the group was unavailable, he said.
Do you already have a remote control?
by the way: how can I unlock the fader for the rear speakers that were installed later?
Look here.
http://de.openobd.org/vw/rns.htm#radio5
Translated on 26-09-2026, 14:33.
PeterK
Post12-12-2004, 18:24    Subject: DSP: McDonald's Missed the Deadline Quote
Good evening, everyone.
The DSP is working again, but only my car knows why. After a while of being stopped, it started working again when I next started the engine. icon_eek.gif Hopefully, the ABS or ESP won't cause any more problems...
Have a good evening, everyone.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Translated on 26-09-2026, 14:34.
PeterK
Post12-12-2004, 18:41    Subject: DSP: McDonald's forgot! Quote
Theresias wrote:
PeterK wrote:
The turn signal could not be activated after locking, and the group was unavailable, he said.
Look here.
dsp is working again, and the code 00025 remains the code for 56.
Since I always have to enter "0" for the sound system (DSP) in the radio settings, I never have the option to select the number of speakers... From this, I conclude that the fader function only applies to MCD systems without a DSP, when the MCD itself is controlling the speakers.
I don't have a remote control... is that a requirement for it to blink?
Peter K.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Translated on 26-09-2026, 14:36.
Theresias
Post12-12-2004, 18:47    Subject: DSP: McDonald's forgot! Quote
I don't have a remote control..., is that a requirement for it to blink?!
Sure.
The horn/lights will only respond if you close/open them using the FFB (Force Feedback Wheel).
The new G5 is also suitable for door cylinder applications.
Translated on 26-09-2026, 14:38.
PeterK
Post12-12-2004, 19:52    Subject: DSP: McDonald's Missed the Deadline Quote
Good evening.
"Last message regarding the car: When four speakers are selected without DSP, the fader works. However, pressing the DSP button resets the fader to the center position."
Since the sound quality with the fader set to the rear isn't as expected (or as I was used to from my previous A4 with active speakers, where the speakers are also mounted high/in the rear of the "shelf"), and now that I know how to fix it, I'll leave it as it is for now!
"Thank you!"
Peter K.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Translated on 26-09-2026, 14:39.
PeterK
Post13-12-2004, 11:40    Subject: DSP: McDonald's Missed the Deadline Quote
Here's something else about the missing DSP:
When making changes to the radio (56), such as saving settings, all sound is temporarily lost (the DSP is disabled). Then, properly shut everything down, remove and reinsert the ignition key, and the DSP will be reactivated.
So, based on my previous actions, I must have always left the key inside... anyway, the key was definitely taken out and put back in, and that's understandable given what happened afterwards!
and goodbye...
Peter K.
golf iv variant
atd 100ps tiptronic
76+ Tkm
t4 womo
133+ Tkm
Translated on 26-09-2026, 14:40.
