Hello, thank you for the answers.
No, I didn't install the larger pump piston because I was advised against it. However, I'm still tempted to do so, especially because the 11mm pump piston is standard equipment in the automatic ALH. However, I think it would be better to use a much smaller nozzle, like 0.156 or something similar.
I'm currently experiencing a vibration throughout the entire engine starting at around 2800 RPM. It's noticeable in the gearshift lever and steering wheel, and it's worst at 3000 RPM, but then it gradually improves.
I don't know what that could be. Golf IV - ALH - Erstzulassung 9/99
