LMM Correction: What Happened?
BERT
Post11-01-2005, 13:59    Subject: LMM Correction: What Happened? Quote
Hello.
in /viewtopic.php?t=3870&highlight=lmm+korrektur
The electronic correction of the LMM signal was discussed. I might also have a similar issue. I have designed a circuit that passes the LMM signal with a gain of 1 up to a voltage of 1.5 to 2V, and for higher input voltages, the gain continues to increase.
This topic hasn't been discussed here for about a year. Is the effort even worthwhile? How much longer can the LMM (likely referring to a specific device or component) be used?
Translated on 01-09-2026, 6:12.
Post11-01-2005, 14:04    Subject: LMM Correction: What Happened? Quote
Hi BERT.
Perhaps it's because, on the one hand, many people find this elaborate modification unnecessary (older TDI models work perfectly well with a simple diode), and on the other hand, some people aren't willing to spend 80 euros to tinker around (developing, replicating, and hoping it works... it will likely cost more than buying a new MAF sensor).
Translated on 01-09-2026, 6:13.
No new posts Electronic Correction for Aging LMM Devices Troubleshooting & Guides
No new posts Pierburg-LMM (alte Form): Korrektur sinkender Messwerte Troubleshooting & Guides
No new posts Wann wurde die Abgaswarnleuchte im Golf TDI verbaut On-Board Diagnostics (OBD)
No new posts LMM Correction at AEL: A User Report Diesel Engine Technology
This topic is locked, you cannot edit or reply. Korrektur der Abgasrückführung On-Board Diagnostics (OBD)
No new posts ESP-Korrektur mit Absteckdorn oder ohne ??? Diesel Engine Technology
