A6/AEL: Why No Speed Above 3000 RPM?
joop
Post06-09-2002, 17:55    Subject: A6/AEL: Why No Speed Above 3000 RPM? Quote
Hello!
'I'm having this problem. The car accelerates normally up to 3000 RPM, but then it stops accelerating. There are no error codes stored. When using a diagnostic tool while driving, the values are correct up to 3000 RPM, but then the actual values for lambda (LD) and air mass drop.'
I've already checked the turbocharger boost hoses, and I don't see any other visible issues.
Who else can help me here...?
'Thank you.'
Sure, here's the translation:
'Best regards,' or 'Sincerely,'.
Okay.
Translated on 19-09-2026, 10:21.
Hannes
Post06-09-2002, 22:03    Subject: A6/AEL: Why No Speed Above 3000 RPM? Quote
Have you ever checked the needle lifter?
Let the engine run at approximately 3000 RPM, and then, by gently tapping the nozzle with the needle valve adjuster, the engine should not start to stumble. If it does, a replacement is necessary.
best regards
Hannes.
Audi Allroad quattro LR, 2004
Audi S6 Avant quattro, 1995
Translated on 19-09-2026, 10:22.
joop
Post07-09-2002, 7:27    Subject: Needle Valve: Definition & Function Explained Quote
Hello.
First, thank you for your help.
But that's a dumb question. Can you explain to me what the needle lift valve has to do with my problem? Wouldn't a defective needle lift valve be noticeable through sporadic fluctuations in performance...?
Best regards.
Okay.
Translated on 19-09-2026, 10:23.
olli
Karma: +46 / -0   Thank you, like it!
Post07-09-2002, 12:10    Subject: A6/AEL: Why No Speed Above 3000 RPM? Quote
"On my car, there was a hose (about 5 mm in diameter) that was located very close to the EGR valve. A broken cable tie caused it to come into contact with the hose, which then melted."
To inspect it, you need to remove the upper motor cover.
I no longer remember exactly whether it connects to a sensor for measuring pressure or vacuum, but the resulting effect was similar.
Performance is normal up to approximately 3000 RPM, after which it drops off significantly.
Olli.
Translated on 19-09-2026, 10:24.
Hannes
Post07-09-2002, 13:23    Subject: A6/AEL: Why No Speed Above 3000 RPM? Quote
It started with occasional jerking when my NHG (presumably a type of engine or component) was faulty, and it happened more and more frequently. Eventually, I also experienced a complete loss of power under heavy load.
Also, you should also check the CAT (computer-aided translation) tool to see if it might be malfunctioning.
best regards
Hannes.
Translated on 19-09-2026, 10:25.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts A3 1.9 TDI not pulling properly Diesel Engine Technology
No new posts A6 2.5 AEL: No More Proper Pull-Through:-(( Diesel Engine Technology
No new posts AJM PUDÜ: 115 HP Engine Not Starting? Diesel Engine Technology
No new posts Passat 3C 125kW not pulling properly Diesel Engine Technology
