I have a 1Z TDI engine with a faulty fuel injection pump that's causing it to misfire.
Now, I'd like to know if there's anything specific I should pay attention to when buying a replacement pump.
Do all fuel pumps from a 1Z TDI engine (Passat, Golf, Audi) fit interchangeably?
Which part numbers can I use?
I have a VAG 028 130 115 MX.
Bosch 046404971
Is it important if I want to buy a relatively new used car?
Can I use a 028 130 115 M as a replacement?
What about the models 028 130 110 and 109?
Please provide the text you would like me to translate from German to English.
Yes, that's perfectly possible.
The "MX" is the replacement pump for the "M".
The "X" indicates that this is a reconditioned pump (Exchange).
Why does your car already have a replacement pump installed?
Thank you very much for your quick response .
The previous owner once had quality issues with the diesel fuel at their usual gas station.
As a result, everyone who could prove they had refueled at that time received a new or refurbished fuel injector, etc.
Okay, then I'll see where I can get it installed once I receive the pump.
Do you recommend VAG or independent workshops?
I think I'll get some quotes.
