Hello guys,
Can anyone tell me what the differences are between the injector nozzles with needle lift control and those used in the V6 TDI engine? Specifically, I'm referring to part numbers 059130202B and 059130202C. The first one is for a manual transmission AKN engine, while the second is for an automatic transmission AKN engine.
Aber worin unterscheiden die sich? Ist der NHG anders? Die Düsenbohrungen? What is the operating pressure?
Are they compatible with each other? Can I also use part number 059130202C in my AKN manual transmission?
"Hello."
AL
Translated on 25-08-2026, 10:11.
