Vag-Com AAT Engine Data Blocks
falkone
Post15-11-2004, 10:28    Subject: Vag-Com AAT Engine Data Blocks Quote
Hello.
After the Opto version refused to communicate with my MSTG, I built the Maik's MAX-232 version based on an article. Now I can access my MSTG, read the error memory, and display 'single readings,' but not 'measure blocks.' I can display these measure blocks for the automatic transmission, but that also worked with the older Opto version. I've also tried messing around with the settings, but nothing has helped. I've also read here that the 1Z has a similar problem, but I haven't found much information about it from the AAT (presumably referring to a specific system or module).
Is there anyone who has actually managed to read the AAT Meas.Blocks?
And I could probably make an even better adapter than the one Maik made.
Please don't suggest that I could buy one – I'm not exactly flush with cash, and the car is already expensive enough. There's also the Alex Weiss adapter, which only adds galvanic isolation, but that wouldn't really benefit me and might even worsen things due to the optocouplers.
Audi 100 (C4), manufactured in 1993, 2.5 TDI (engine code: AAT), automatic transmission.
Toshiba, very old laptop, 133MHz, 32MB.
Translated on 06-09-2026, 14:51.
wolfi_b
Post15-11-2004, 10:47    Subject: Vag-Com AAT Engine Data Blocks Quote
With a little searching, you would have found it: /viewtopic.php?t=7694
"The AAT with the initial software version only displays measurement block 00."
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 06-09-2026, 14:53.
Trecker Treiber
Post15-11-2004, 20:40    Subject: Vag-Com AAT Engine Data Blocks Quote
The measurement block 00 only applies to AAT versions 1 and 2. Starting with version 3, you can also read out other measurement blocks. You can identify whether you have an AAT version 3 by checking if it has an engine cover or if the control unit number ends in 'E' or 'F'.
Translated on 06-09-2026, 14:54.
davie
Post03-01-2005, 13:25    Subject: Vag-Com AAT Engine Data Blocks Quote
Hello!
I bought a '92 C4 with an AAT (115 hp) engine.
I am unable to perform a diagnosis using VCDS. I have tried using VW tool and VDS pro as well, but I am not getting any communication.
Ref.: 0281001129.
We have had success with Bosch ESI, which allows us to diagnose a number of issues, but we have had no success with VAG-COM.
Can this type of diagnostic tool be used with VAG-Com?
This forum is really great; I've learned a lot.
Best regards.
David.
Translated on 06-09-2026, 14:55.
Uwe@Ross-Tech
Post03-01-2005, 18:43    Subject: Vag-Com AAT Engine Data Blocks Quote
Try going to Options -> Start Baud -> 240.
-Uwe-
Translated on 06-09-2026, 14:56.
christians
Post03-01-2005, 20:52    Subject: Vag-Com AAT Engine Data Blocks Quote
The baud rate alone didn't help me. If I really need the diagnostic information urgently, I'll probably have to get a smart interface.
Gruß Christian
davie
Post05-01-2005, 16:30    Subject: Vag-Com AAT Engine Data Blocks Quote
Hello!
What kind of intelligent interface are you referring to?
Mine has a dual K/L interface.
Best regards.
David.
Translated on 06-09-2026, 14:57.
Theresias
Post05-01-2005, 16:39    Subject: Vag-Com AAT Engine Data Blocks Quote
A HEX interface.
Post05-01-2005, 17:35    Subject: Vag-Com AAT Engine Data Blocks Quote
Sure, here's the translation:
"Like this one:"
http://shop.dieselschrauber.de/index.php/cPath/23
Translated on 06-09-2026, 14:58.
davie
Post05-01-2005, 17:47    Subject: Vag-Com AAT Engine Data Blocks Quote
Will I be successful with this interface?
What is the difference between a normal interface and a Hex interface (besides the registration)?
Best regards.
Post05-01-2005, 18:07    Subject: Vag-Com AAT Engine Data Blocks Quote
especially the product features, as explained in the respective descriptions icon_smile.gif.
Let me list the highlights:
- Check if the K/L lines are functioning correctly (vehicle wiring harness is okay, radio installation is okay).
- The diagnostic adapter has its own intelligence, which means that the timing of the diagnostic protocols can no longer be disrupted by the "non-real-time operating system Windows."
- CAN-Bus support.
- Generic OBD2 capability (beta testing, as it's brand new).
The details are in the descriptions, and it wouldn't make much sense to copy them here again.
Translated on 06-09-2026, 14:59.
davie
Post06-02-2005, 15:21    Subject: Vag-Com AAT Engine Data Blocks Quote
Hello!
Success!
With win98 and a baud rate of 240, I was successful. I spoke with my Audi, and she said everything was OK, no errors. I was good to her, and she loves me too! icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Thank you for your help!
David.
Translated on 06-09-2026, 15:01.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Smoking engine after engine/turbo replacement Diesel Engine Technology
No new posts TDI Engine with Gas Transmission: Possible? Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts AEL engine in T4 - Ex-ACV Diesel Engine Technology
