AFN Engine Problems: Common Issues & Solutions
Rüttelplatte
Post10-09-2002, 21:58    Subject: AFN Engine Problems: Common Issues & Solutions Quote
Hello!
Here's the translation:
'This is about the following vehicle:'
Seat Ibiza GT TDI.
MKB: AFN engine with switchable chip (110/140 hp) from ******** (installed for approximately 45,000 km).
'Problem: The 'turbo boost' now kicks in around 2300 RPM, instead of the usual 1800 RPM. However, after that, it seems like all the power is available, and the maximum speed is reached. There's just a slight hesitation around 3500 RPM. Whether the 'chip' is installed or not, it doesn't make a difference. In the past, I experienced a complete loss of power. However, after cleaning the mass airflow sensor (Pierburg) with brake cleaner, everything was back to normal.'
So far, I have:
Have the error memory read: No entry icon_sad.gif.
LMM cleaned: Unsuccessful.
Visual inspection of hoses, connectors, etc.
The air and diesel filters are in good condition.
Does the AGR click when actuated externally, so it's working correctly, right?
Disconnecting the AGR (Abgasrückführung) system will not achieve anything.
VTG mechanism is operating smoothly (checked with a syringe).
Do you have any ideas?
Thank you in advance!
Translated on 18-10-2026, 1:33.
Post11-09-2002, 19:18    Subject: MKB AFN Engine Problems: Troubleshooting Guide Quote
Rüttelplatte wrote:
The AGR clicks when actuated externally, so it's okay, right?
Disconnecting the AGR does nothing.
Hi.
What exactly do you mean by AGR? The solenoid valve (which should click) or the diaphragm valve (if that clicks, it doesn't necessarily mean the valve is completely closed!)
As a precaution, disconnect the intake hose before the EGR valve and check the membrane valve's functionality by visually inspecting it and using a vacuum test.
The most important thing is whether it really seals completely (without creating a vacuum).
Possibly make it a little easier to operate.
Translated on 18-10-2026, 1:36.
Rüttelplatte
Post13-09-2002, 10:19    Subject: MKB AFN Engine Problems: Troubleshooting Guide Quote
The AGR clicks when operated externally, so it's okay, right?
Disconnecting the AGR will not achieve anything.
Hi.
Possibly, make it somewhat easier to operate.
I didn't check the solenoid valve. I manually actuated the diaphragm using a syringe, and it clicked. However, I don't know if the valve actually closed completely. Yesterday, I scheduled an appointment at the workshop for today to have a test drive with a diagnostic tool. And what happened? The problem suddenly disappeared on the way home! Today, I still had the error memory read: No entries. I wonder if some valve was stuck. Hopefully, it stays that way.
Translated on 18-10-2026, 1:38.
No new posts Motor problems TDI 150 GTI Diesel Engine Technology
No new posts ALH Engine Problems: Common Issues & Fixes Diesel Engine Technology
No new posts Peugeot 206 HDI 90: Engine Problems & Solutions Diesel Engine Technology
No new posts Motor problems with a Sharan 1.9 TDI 110 hp Diesel Engine Technology
