Resolution: How to Solve :-) Problems | Posts 16+
Go to page: Previous  1, 2
Diesel0815
Post10-02-2005, 13:59    Subject: Resolution: How to Solve :-) Problems Quote
Hey everyone,
Okay, I finally did it.
It wasn't almost the crankshaft bolt (I have a 1Z engine).
Last week I drove 500 km, and suddenly the fuel injection system started giving me problems (which had never happened before).
Unfortunately, I also had to stop and rest.
Once I finally got my car to my friend's Bosch service center, we checked everything thoroughly, and we quickly realized that...
--> that the pulley for the timing belt (which is located on the crankshaft) was worn out and, to put it mildly, 'wobbling.' (This wobble probably causes the engine control unit to shut off the fuel injection pump --> which is why I initially thought the fuel injection system was faulty).
So, we've made the front of the crankshaft flat again and installed a new rotor.
Lo and behold, the diesel is running perfectly!
Okay, so once again, many, many thanks to EVERYONE!!
Dave.
Translated on 14-08-2026, 7:49.
ab_tdi
Post10-02-2005, 14:08    Subject: Resolution: How to Solve :-) Problems Quote
This is a common issue with 1Z engines.
Mine had the same issue, but it didn't turn out to be as bad as it was for you.
'The timing belt jumped a tooth on my engine, and it bent all the valves.'
That was an expensive pleasure.
I recommend that everyone with a 1Z engine have it checked by a mechanic.
Let it be.
Translated on 14-08-2026, 7:52.
No new posts TDI engine starts poorly Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine won't start, Mj 1999 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf III TDI Starting Problems: 1996, 1Z Engine Diesel Engine Technology
This topic is locked, you cannot edit or reply. TDI engine starts poorly when warm! Diesel Engine Technology
No new posts Golf 3: 1.9 TDI Engine Starting Problems Diesel Engine Technology
No new posts Engine hard to start when warm Diesel Engine Technology
