Boost Pressure Fluctuations
Henrik Lyck
Post10-02-2005, 23:21    Subject: Boost Pressure Fluctuations Quote
Hello, I'm new to the forum. I'm from Denmark, so I might not always use the correct word for some parts.
I'm experiencing fluctuating boost pressure, just like others.
I recently bought an Audi 80 Avant TDI, but I'm having a problem with it. When I accelerate fully, I can hear the turbocharger spooling up and then winding down again, which is also noticeable in the performance. I replaced the mass airflow sensor (MAF), but that didn't help. The pressure sensor on the wastegate seems to be working correctly, and the magnetic valve is receiving 12.3V. I even removed it and checked it; it clicks and opens and closes when I apply 12V.
'Today I connected a pressure gauge to the intake manifold. When I give it gas, the boost pressure briefly rises to 1-1.2 bar, then drops to a stable 0.8 bar for a short time. Then I feel small, rapid vibrations, which I think is normal. However, at the same time, the boost pressure starts fluctuating between 0.2-0.3 and 0.8 bar.'
The engine is a 1Z.
What should I do now to find the error?
Best regards.
Henrik Lyck.
Translated on 30-07-2026, 1:38.
Marco
Post10-02-2005, 23:42    Subject: Boost Pressure Fluctuations Quote
Is the wastegate adjustment easy to operate?
Translated on 30-07-2026, 1:40.
Henrik Lyck
Post11-02-2005, 0:03    Subject: Boost Pressure Fluctuations Quote
Yes, I unscrewed the pressure sensor from its bracket and everything came off easily.
Post11-02-2005, 8:15    Subject: Boost Pressure Fluctuations: Troubleshooting Guide Quote
Henrik Lyck wrote:
What now, how do I proceed to find the error?
Connect the pressure hose directly from the intake manifold to the turbocharger housing.
If the pressure is then set to a constant value of approximately 0.6 bar, the turbocharger is working correctly.
Then check the thin hoses or replace the solenoid valve.
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 30-07-2026, 1:41.
Henrik Lyck
Post11-02-2005, 17:43    Subject: Boost Pressure Fluctuations Quote
I just tried the test mentioned above. The charging pressure is about 0.6 bar, and the vibrations are still present, but that's probably due to the intake system.
The charging pressure is now constant. I already replaced the thin hoses a week ago. If the solenoid valve is working as I described, could it still be defective?
Translated on 30-07-2026, 1:42.
Post11-02-2005, 18:21    Subject: Boost Pressure Fluctuations Quote
Henrik Lyck wrote:
The charging pressure is now constant... if the solenoid valve works as I described, could it still be defective?
Probably yes, but that's something that 1Z practitioners should comment on...
Translated on 30-07-2026, 1:43.
Jan03
2010 Volkswagen Polo
Post11-02-2005, 19:37    Subject: Boost Pressure Fluctuations Quote
In the solenoid valve, a small metal bolt with rubber ends moves back and forth inside a cylinder. If a foreign object gets through, the rubber ends can easily break, which compromises the seal. Additionally, oil tends to accumulate in the solenoid valve. I would replace this part, especially since it's not that expensive when bought in Germany (about 32 Euros). In Denmark, it costs almost three times as much! (approximately 650 DKK = 86 Euros) icon_evil.gif
There are now some Volkswagen dealerships that ship cheaper parts to Denmark, which typically saves around 50%.
/Jan
Translated on 30-07-2026, 1:44.
Henrik Lyck
Okay, thank you for your help; hopefully I can find the error.
Does a practitioner of 1Z have any comments?
By the way, the engine has an EGR system.
Translated on 30-07-2026, 1:45.
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost pressure fluctuates at partial load, according to LDA Diesel Engine Technology
No new posts Temparaturanzeige schwankt Diesel Engine Technology
No new posts T4 2.5 TDI: Fuel injection timing fluctuates On-Board Diagnostics (OBD)
No new posts Leerlauf schwankt A4 2.5TDI Diesel Engine Technology
