Smilinged Guest
24-02-2005, 12:16 Subject: ECU Data Blocks: What You Need to Know |
Measurement data blocks in the control unit?
Hi everyone.
I was wondering if there might be a list or even a book that explains the individual measurement blocks, from 1 to 256 or beyond.
I mean this applies to other control units as well, not just the engine control unit.
Translated on 15-10-2026, 12:34.
Theresias Guest
24-02-2005, 12:29 Subject: ECU Data Blocks: What You Need to Know |
Listen... Partially...
Which vehicle, which control units? Part numbers?
Translated on 15-10-2026, 12:35.
Smilinged Guest
25-02-2005, 22:21 Subject: ECU Data Blocks: What You Need to Know |
Engine control unit, ABS control unit, comfort control unit, instrument cluster.
Best for VW and Audi.
if possible
Theresias Guest
25-02-2005, 22:23 Subject: ECU Data Blocks: What You Need to Know |
Welches Fahrzeug? Part numbers?
There are no general lists available, but it is sometimes possible to create lists specific to certain control units.
Translated on 15-10-2026, 12:36.
tuner01 Blaumann
27-02-2005, 11:14 Subject: ECU Data Blocks: What You Need to Know |
I'm just hanging around, wondering  .
I need the list for a Golf IV Cabrio, model year 2001.
sunny Guest
27-02-2005, 14:20 Subject: ECU Data Blocks: What You Need to Know |
hi,
and is there anyone else who might need such a list for a Seat Ibiza, type 6K1, 1.9 TDI, manufactured in November 1998, engine code AFN
Translated on 15-10-2026, 12:37.
Theresias Guest
27-02-2005, 15:24 Subject: ECU Data Blocks: What You Need to Know |
Specifically, which control units and which part numbers?
...is there anyone else who might need such a list for a Seat Ibiza, type 6K1, 1.9 TDI, manufactured in November 1998, engine code AFN  .
That's a bit more concrete, but it's still not really exciting.
If you want us to help you, you need to provide specific information by reading out and posting the part numbers using VAG-COM.
Translated on 15-10-2026, 12:38.
sunny Guest
27-02-2005, 15:44 Subject: ECU Data Blocks: What You Need to Know |
sorry
028 906 021 EK
and 1.9L R4 EDC G00SG 1438.
and I also need the corresponding labels in German (for the 409.1 shareware version), and a small instruction on where I need to copy them (I'm an IT novice  ).
Translated on 15-10-2026, 12:39.
27-02-2005, 18:57 Subject: ECU Data Blocks: What You Need to Know |
@ Sunny
 Please use the search function.
"Label files" can get you surprisingly far.
including, among other things, the file being searched for.
Where does it go: It's quite complicated... to the other label files, where else would it go?
m; Transparency, Teamwork
Translated on 15-10-2026, 12:40.
Profile PM Garage |
Theresias Guest
27-02-2005, 19:03 Subject: ECU Data Blocks: What You Need to Know |
What to do with it: It's quite complicated... put it with the other label files, where else would it go.
It is recommended that you save/copy your own/additional files to the '/labels/user/' subdirectory within the VAG-COM folder, unless otherwise specified. This folder is searched first, before the folder for the specific distribution and the main '/labels/' directory.
Translated on 15-10-2026, 12:41.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
27-02-2005, 19:04 Subject: ECU Data Blocks: What You Need to Know |
Profile PM WWW Garage |
Theresias Guest
27-02-2005, 21:44 Subject: ECU Data Blocks: What You Need to Know |
028 906 021 EK
http://download.openobd.org/labelfiles/02-01.lbl
http://download.openobd.org/labelfiles/german/028-906-021-AFN.lbl
The file for the AFN has been lying around for a while, but no one has asked for it yet.
@Rainer, I took the liberty of partially using your target values.
It's quite possible that the 409.1 error is occurring due to a problem with the redirection.
This issue was fixed in a later version, and there are no problems with version 500.x.
Possibly, therefore, rename the actual label file accordingly.
...and I would also need appropriate labels in German (for the 409.1 shareware version)...
For the engine control unit (ECU), see above. Which other parts do you need?
...and a small guide on where I need to copy and paste it (I'm an IT novice  )
Translated on 15-10-2026, 12:43.
