Hi everyone, I have a question for all the diesel experts. Our T4 TDI doesn't have the same power it used to (75,000 km). It only rarely reaches 200 km/h. A new MAF sensor was installed only 3 months ago. I recently removed the K&N filter because I've heard that it can damage the MAF sensor (let's not start a discussion about that thing!!!
). In my A3, the engine started misfiring again after an oil change, so I replaced the filter with the original one. Then I cleaned the MAF sensor and the intake air temperature sensor, and it's running smoothly again. But it's not that easy with the T4. It has a different type of MAF sensor that's encapsulated, so you can't easily access the sensor itself. Is there a way to clean it, or what could be the cause?
