Hi Michael,
Quote: |
1.9 l SDI/TDI
AFN, AHU, AEY, AGD, ALE
Engine revs up to approximately 2,000 RPM after starting, experiencing a lack of power.
Approximately 120 km/h with error code 1237, fuel valve N109.
Warning light flashing.
Please provide the German text you would like me to translate into English.
Cause: The electromechanical shut-off valve is triggered during the safety self-diagnosis.
identified as defective.
Series: Modified shut-off valves.
From 04.98.
Repair of the electromechanical shut-off valve using the...
Part set 028 198 135. |
Do you also know the cause of the "defect detection"? For example, I could imagine a coil resistance falling outside the tolerance range stored in the motor control unit.
But if the engine still starts, then it can't be a "real" defect. Does the EDC also detect if the device doesn't close properly?
Otherwise: great idea with the "insider documentaries"!
