Window Regulator/Door Control Unit Problem
AFNTDI1,9
Post10-04-2005, 12:01    Subject: Window Regulator/Door Control Unit Problem Quote
Hello!
Yesterday, I wanted to check the error memory of my door control units because the central locking and rear window lifters weren't working.
After checking the comfort control unit, the front window lifters and the central locking system also stopped working.
He's only getting an error message now, indicating that he can no longer communicate with any of the four doors.
Does anyone have any advice?
Best regards.
Translated on 07-10-2026, 16:38.
Theresias
Post10-04-2005, 15:21    Subject: Window Regulator/Door Control Unit Problem Quote
Which vehicle? Year of manufacture/model year?
Part number for the comfort control unit?
Foreign radio?
VAG-COM version? Interface (manufacturer)?
Translated on 07-10-2026, 16:39.
AFNTDI1,9
Post10-04-2005, 15:28    Subject: Window Regulator/Door Control Unit Problem Quote
forgotten
Passat TDI AFN, manufactured in 1998.
I don't know the part numbers for the control unit!
VAG-COM 311.2 Shareware.
I bought this adapter from the online diagnostic shop.
The airbag error could be easily cleared.
Original Beta radio:
Best regards.
Translated on 07-10-2026, 16:40.
Theresias
Post10-04-2005, 16:03    Subject: Window Regulator/Door Control Unit Problem Quote
As long as you've only read the error memory, any subsequent malfunction would likely be coincidental, unless the control unit is defective, which would then cause these problems.
Translated on 07-10-2026, 16:41.
AFNTDI1,9
Post10-04-2005, 17:07    Subject: Window Regulator/Door Control Unit Problem Quote
I just wanted to know why my rear control units weren't working.icon_sad.gif
Too bad...
Theresias
Post10-04-2005, 17:10    Subject: Window Regulator/Door Control Unit Problem Quote
What errors are currently stored?
AFNTDI1,9
Post10-04-2005, 21:27    Subject: Window Regulator/Door Control Unit Problem Quote
4 pieces.
For each door, there is no communication with the control units.
Theresias
Post10-04-2005, 21:31    Subject: Window Regulator/Door Control Unit Problem Quote
Yes, I was already aware of that, but WHICH ones?!
Generally, it would be helpful to check the wiring.
and if necessary, disconnect the comfort control unit from the power supply for about fifteen minutes.
almost a hard reset.
Translated on 07-10-2026, 16:42.
rinderwahnsinn
Post10-04-2005, 22:00    Subject: Window Regulator/Door Control Unit Problem Quote
The comfort control unit malfunctions frequently and can only be reset by removing and reinserting the fuse.
A cable break could also be considered as a possible cause of the problem (door guides).
CU.
Translated on 07-10-2026, 16:43.
AFNTDI1,9
Post10-04-2005, 22:20    Subject: Window Regulator/Door Control Unit Problem Quote
After resetting the fuse, the driver's side window lifter is working again.
However, the others did not.
I'm going to start measuring things now!
"Thank you."
Best regards.
vagtuning
Post13-04-2005, 21:58    Subject: Window Regulator/Door Control Unit Problem Quote
I would be very surprised if they hadn't included the premium 'Comfort' package. It wouldn't be the first time!
Translated on 07-10-2026, 16:44.
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf 1J, defective window switch safety sensor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Window lifter: Repair tip for Golf IV platform Troubleshooting & Guides
No new posts Faulty Door Control Units: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts VTG Problem: Troubleshooting & Solutions Diesel Engine Technology
No new posts agr new problem Diesel Engine Technology
No new posts Cruise Control Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
