Channel 4 Adaptation: A Guide
BlauBaer
Post01-10-2002, 17:01    Subject: Channel 4 Adaptation: A Guide Quote
hi...
I was just trying to adjust the ESP settings using VAG-Com to make it intervene earlier, but unfortunately, I can't access the adaptation for channel 4... for some reason. I'm logged in with the code 12233, and I can change all the other channels (e.g., adjust the idle speed), which isn't a problem. But for channel 4, it always shows 'N/A.'
What's happening again?
Translated on 13-10-2026, 6:41.
No new posts Channel 4 Adapter Not Working? Troubleshooting Guide. On-Board Diagnostics (OBD)
No new posts VAG Com Channel 7 On-Board Diagnostics (OBD)
No new posts PDC to OPS: Converting 4-Channel G5 Electrical Systems, Vehicle Electronics, Multimedia
No new posts AFB VAG COM measurement channel 20, measuring block 1? Diesel Engine Technology
