Does colder intake air have any benefits?
rl2664
Post29-09-2002, 19:48    Subject: Does colder intake air have any benefits? Quote
I want to modify the inner fender liner on my AFN Passat to allow more air to flow through the intercooler, resulting in colder intake air.
Does it make a difference, or is it something you can just skip?
Sure, here's the translation:
'I would appreciate a short answer.'
Best regards.
Ronny.
Translated on 05-07-2026, 15:02.
Gremlin
Post29-09-2002, 20:01    Subject: Does colder intake air have any benefits? Quote
Click on the corresponding link 'intake air temperature for Audi A3' in the menu on the left.
CU Gremlin.
rl2664
Post29-09-2002, 20:10    Subject: Does colder intake air have any benefits? Quote
Hello Gremlin,
Oh man, this is so embarrassing... Thank you very much!
Then we can safely say that a perforated inner fender doesn't really offer any benefits, right?
Best regards.
Ronny.
Translated on 05-07-2026, 15:03.
H-P
Post30-09-2002, 19:10    Subject: Does colder intake air have any benefits? Quote
I modified the bumper to allow more air to flow towards the intercooler (IC), so I cut out some additional openings and used a heat gun to soften the original air ducting plastic.
bent, so that more air can come into contact with the heat sink.
I also made a hole in the wheel well, at the level of the lower control arm.
in size 15x15cm. I repaired this hole using sheet metal.
riveted and the rear fender cover reattached.
Unfortunately, one can only imagine icon_mad.gif more performance.
Experience makes you wise.
Best regards, H-P.
Translated on 05-07-2026, 15:04.
A4Tommy
Post01-10-2002, 23:48    Subject: Does colder intake air have any benefits? Quote
Has anyone ever experimented with LLK (liquid lens kit) mounting?
That would be interesting!
See you soon.
Translated on 05-07-2026, 15:05.
madcatxyl
Post02-10-2002, 5:36    Subject: Does colder intake air have any benefits? Quote
I have already conducted tests using a local exhaust ventilation system. Audi A6 2.5 AEL.
Specifically, I installed a radiator fan from a Golf behind the intercooler (under continuous load) after doing some sheet metal work.
It's quite a bit of work to assemble this thing, and there's very little space to work with.
Therefore, I also made a mistake => In my opinion, the additional cooling is significantly noticeable both when starting from a standstill and in city driving, but the effect diminishes on the highway. <<< In this case, the fan also burned out due to the lack of pressure equalization flaps. icon_sad.gif
I haven't had time to replace and improve the fan yet, but I definitely will. The car feels more agile from a standstill and generally more responsive (my impression; I couldn't measure it precisely, except for the hill climb test, where it was about a second faster).
Best regards, Frank.
Translated on 05-07-2026, 15:06.
No new posts Cooling Charge Air: Ideas & Tips Diesel Engine Technology
No new posts Charge Air Cooler: Buy Now & Save! Diesel Engine Technology
No new posts Turbocharger Noise: Causes & Solutions Diesel Engine Technology
No new posts Intercooler Logs: PD & VP Performance Data Diesel Engine Technology
