Emergency mode (Solution)
Post02-05-2002, 14:34    Subject: Emergency mode Quote
A common cause is excessive boost pressure. This is often indicated by a significant loss of power, and the maximum achievable speed is approximately 120 km/h. Please provide the text you would like me to translate from German to English. I will then provide the translation.
- Commonality of VTG adjustment.
- Vacuum sensor for adjusting the VTG (Variable Track Geometry), particularly susceptible to failure due to spring breakage.
- Magnetic valve for turbocharger pressure control.
Since there can be various other causes for the engine malfunction, it is recommended to have the error memory read as soon as possible. Experience shows that some workshops simply delete the error code if they can't do anything with it, so be careful.
Ratings - Emergency mode
No new posts Emergency Mode: Reproducible Based on Outside Temperature Diesel Engine Technology
No new posts Emergency Mode Sharan 110HP: Overload? Diesel Engine Technology
