ASZ Setpoints: Values and Configuration
wbuchi82
Karma: +9 / -0   Thank you, like it!
Post10-05-2005, 18:26    Subject: ASZ Setpoints: Values and Configuration Quote
Hi!
Since I recently switched from AHF to ASZ, I immediately downloaded the new target data for the ASZ engine and performed a test run. During this test run, I noticed an inconsistency in the target data. Specifically, the target data specifies a range of 16...34 icon_question.gif for smoke reduction. However, during my test runs, I achieved values of 48..56 icon_confused.gif.
In this case, my measured values actually seem more realistic, as the smoke limitation curve is always above the torque limitation curve. The target value for the torque limitation is specified as 25...51 icon_question.gif.
Where exactly is the bug icon_twisted.gif?
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi A3 Ambition, Bj.02, ASZ - SoftwareTuning 160PS
Multimedia-CarPC 2,4GHz - 1GB RAM - 300GB HDD - 8" Tochscreen
Translated on 11-08-2026, 22:10.
Back to top Profile PM Email
Post10-05-2005, 18:41    Subject: ASZ Setpoints: Values and Configuration Quote
What target data is displayed on the page in the article?
Translated on 11-08-2026, 22:12.
wbuchi82
Post10-05-2005, 19:01    Subject: ASZ Setpoints: Values and Configuration Quote
yes!
"By the way, are there any other engines where the target value for smoke reduction is specified as lower than the torque limit?" (Referring to engine codes like ATD and AXR), "but I don't have any measured values for those."
wbuchi82
Post12-05-2005, 19:23    Subject: ASZ Setpoints: Values and Configuration Quote
no new findings?
Translated on 11-08-2026, 22:13.
Post12-05-2005, 21:05    Subject: ASZ Setpoints: Values and Configuration Quote
Sorry, the table is from Michael II. I don't have easy access to the corresponding data in order to correct it.
No new posts Target values for 6-cylinder engines. VP AYM Technical Data
No new posts PD ARL Setpoints: Values and Optimization Diesel Engine Technology
No new posts Looking for ideal values Diesel Engine Technology
No new posts AU: Setting Abregel Thresholds - Explained Diesel Engine Technology
No new posts T4 Engine MKB: Target Values & Specs Diesel Engine Technology
