Vibrations - Problem with injection timing?
Marzocchi
Post09-06-2005, 19:19    Subject: Vibrations - Problem with injection timing? Quote
Hello, I'm experiencing the following symptoms:
Severe engine vibrations in all gears, both while driving and at a standstill, with and without the clutch engaged. The vibrations are most noticeable at low RPMs and then again between 2000 and 3000 RPM. It's significantly better, or at least normal.
The vibrations travel all the way to the pedals and the gear lever.
The ZMS (presumably referring to a specific component) was replaced along with the clutch, but there was no improvement.
I just bought a VAGCOM device and read the error codes.
"The following error occurred:"
17656 Injection Start Regulation: Control deviation P1248 - 35 - 00.
Who knows what that (exactly) means. And what should I do now?
Thank you, best regards, Bernd.
Golf IV - ALH - Erstzulassung 9/99
Post09-06-2005, 19:37    Subject: Vibrations - Problem with injection timing? Quote
No new posts Documentary about vibrations starting at approximately 12... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary about unusual engine noises and vibrations Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vibrations On-Board Diagnostics (OBD)
No new posts Injection start TDI AFN 81 kW Diesel Engine Technology
No new posts Injection Start: Timing & Optimization Diesel Engine Technology
No new posts VAG-COM: Diagnose Injection Timing Diesel Engine Technology
