Hello everyone,
A friend is having a problem with his Renault Megane 1.9DTI... the starter motor is turning, you can visibly see fuel flowing through the lines, but the engine isn't starting.
If you crank it for 3-4-5 times, it starts with a slight hesitation, but then runs without any problems.
The car has 216,000 kilometers on the odometer, and the last service was 5,000 kilometers ago.
Where should we start looking...? I was already thinking about the diesel filter, but fuel is definitely being supplied... The glow plugs are new (although they shouldn't be the problem now)... He also has a new battery... and the error memory is EMPTY
