Question about the glow wire test
haehnlein
Post11-10-2002, 17:05    Subject: Question about the glow wire test Quote
Hello!
I had some starting problems with my Passat 1Z, so I held a test lamp to the spark plugs -> I couldn't even see the test lamp flicker. Is it possible that they can fail so completely that nothing moves electronically? If my old Passat 32b had defective spark plugs, at least the test lamp still worked a little (I've only been driving a TDI for two weeks: I didn't think that these engines still depended on the spark plugs). Thanks in advance!!!!!!!
Post11-10-2002, 17:40    Subject: Burned out Quote
Why shouldn't a light bulb be able to burn completely, but also partially?
Incidentally, a light bulb test is only meaningful if you use a main headlight bulb.
Due to their high power consumption, even minor defects in the bulbs ("1/4 burned out") icon_wink.gif icon_razz.gif) is noticeable due to the tired flickering, while a normal test lamp still shines brightly.
No new posts non-TDI Frage Diesel Engine Technology
No new posts MWB 11: Questions and Answers On-Board Diagnostics (OBD)
No new posts Question about the AGR system in the ACV/T4 (Sorry) Diesel Engine Technology
No new posts Oil Question Diesel Engine Technology
