Alternative ECU: Find the Right Control Unit
prittstift69
Post28-06-2005, 22:03    Subject: Alternative ECU: Find the Right Control Unit Quote
It's about engine testing on a dynamometer.
The test engine is a natural gas engine based on a VW 1.9 TDI (AGR) and features direct natural gas injection.
I am looking for an alternative engine control unit (ECU) to control the natural gas injectors (similar to a diesel common-rail system). The aim is to obtain the speed and other signals, if possible, from the sensors already installed in the vehicle.
Currently, a so-called "Autobox" from the company dSPACE is being used. It's a professional solution, but not exactly inexpensive.
So far, I have come across the following control units:
Megasquirt - Open-source engine control unit.
www.megasquirt.de
EMS 8860 Sequential Motorsport.
www.luepertz-motorsport.de/html/8860_s_sport.html
Ontronic.
www.ontronic-efi.com/
Unfortunately, based on the initial assessment, the devices are officially intended for use only with gasoline engines.
Has anyone here had experience with any of these products, or does anyone know of any alternatives for use in diesel engines?
Thank you for your help.
Stephan.
Translated on 20-09-2026, 11:33.
hb2000
Post29-06-2005, 8:40    Subject: Alternative ECU: Find the Right Control Unit Quote
hello,
So far, I haven't seen any freely programmable engine control units (ECUs) specifically for diesel engines. However, the MegaSquirt should theoretically be programmable for a diesel engine, even though it is officially certified only for gasoline engines.
Translated on 20-09-2026, 11:35.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ambient Pressure Sensor for VW G3 AFN ECU On-Board Diagnostics (OBD)
No new posts Gear diagram Diesel Engine Technology
No new posts Labeldata for 038 906 019 CG Diesel Engine Technology
No new posts Explosion Diagram for VE 4 - Search Diesel Engine Technology
