Hydro lifter test: Questions and answers
haehnlein
Post04-10-2002, 17:03    Subject: Hydro lifter test: Questions and answers Quote
Hello!
I just checked my hydraulic lifters (TDI, 1Z, 174,000 km) following Etzold's instructions (valve clatter during cold start) and found that, in principle, all the lifters can be moved slightly with a wooden wedge under light pressure. According to the literature, the wear limit is 0.1 mm. Do I now need to replace all the lifters, or did I do something wrong icon_confused.gif? Thank you in advance icon_wink.gif.
Best regards, Christian.
Translated on 21-10-2026, 5:44.
olli
Karma: +46 / -0   Thank you, like it!
Post05-10-2002, 13:32    Subject: Hydro lifter test: Questions and answers Quote
If the engine oil was properly warm and the machine had been run at higher RPMs (greater than 2500) before the test, then the test should have provided accurate results.
It seems that the type of oil used has quite an influence on the function of the hydraulic lifters. Before replacing them, which should ideally be done during the next timing belt change, I would first try a different oil (e.g., 10W xx instead of 5W xx or 0W xx).
Olli.
Translated on 21-10-2026, 5:45.
Jürgen
Post08-10-2002, 10:52    Subject: Hydraulic Lifters: Problems & Solutions Quote
Hydraulic lifters are quite affordable when purchased as a complete set from auto parts stores. However, they are ridiculously expensive for VAG vehicles, even though they are made by the same manufacturer. But, a slight rattling noise during cold starts is acceptable as long as the rattling subsides after a few seconds (due to oil pressure!).
Jürgen
Passat AFN / Golf AHF
Translated on 21-10-2026, 5:46.
haehnlein
Post08-10-2002, 11:00    Subject: Hydro lifter test: Questions and answers Quote
Thank you! I left those things as they are (if it works, don't fix it) icon_lol.gif.
Translated on 21-10-2026, 5:47.
Elwin
Post14-10-2002, 16:45    Subject: Hydro lifter test: Questions and answers Quote
I used a product in New Zealand that 'fixes' rattling noises. I've also tried it on a TDI engine before. (Sorry for my bad German.)
Japanese imported cars with contaminated hydro stoppers are noticeably quieter than before. Even older hydro stoppers are becoming quieter.
If you are interested, please send me an email.
Elwin.
Translated on 21-10-2026, 5:48.
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
No new posts MWB 11: Questions and Answers On-Board Diagnostics (OBD)
No new posts Question about the AGR system in the ACV/T4 (Sorry) Diesel Engine Technology
No new posts Oil Question: Get Answers Now! Diesel Engine Technology
