Ventoman Guest
13-10-2002, 10:12 Subject: LMM: What is LMM? Explanation & Meaning |
Hi!
I have a mass airflow sensor (MAF sensor) from Pierburg that is unfortunately defective. Can I install a Bosch MAF sensor in my VW Vento (1Z)? The VW part number is the same.
'Thank you.'
Translated on 26-10-2026, 22:30.
SirBiBi Guest
13-10-2002, 20:18 Subject: LMM: What is LMM? Explanation & Meaning |
Hi Ventoman,
As far as I know, a VW part number is a unique identifier for a VW component and is not reused.
It means that, in my opinion, you can safely install the LMM.
Best, Björn.
Translated on 26-10-2026, 22:31.
Docter Guest
14-10-2002, 10:52 Subject: LMM: What is LMM? Explanation & Meaning |
It depends on the design.
The Bosch mass airflow sensors (MAF sensors) that I'm familiar with have a different design and installation compared to the Pierburg sensor from the 1Z engine. I'm not entirely sure if there are other variations. However, I would be very cautious.
Translated on 26-10-2026, 22:32.
edward Guest
14-10-2002, 14:23 Subject: LMM: What is LMM? Explanation & Meaning |
In my opinion, the internal structure of the mass airflow sensor (MAF) should not be different; only the shape of the air filter housing might vary. If the VW part number for the MAF is the same, then it should be the same component.
Docter Guest
14-10-2002, 14:36 Subject: LMM: What is LMM? Explanation & Meaning |
No problem if the vehicle identification number (VIN) is the same.
However, there are hot-wire mass airflow sensors and hot-film mass airflow sensors, so they are definitely different.
The external dimensions also vary in some cases.
Translated on 26-10-2026, 22:33.
Ventoman Guest
14-10-2002, 23:15 Subject: LMM: What is LMM? Explanation & Meaning |
hi again.
The part looks (as far as I can tell from the picture) like my current LMM.
Sure, here is the translation:
'Here is the following description:'
'Mass airflow sensor from BOSCH for VW and AUDI, Bosch part number 0 281 002 46; VW part number 074 906 461B.'
The VW part number matches the one on my mass airflow sensor, except for the 'B' at the end.
Can I buy it now with a clear conscience?
Thanks again for your answers.
Translated on 26-10-2026, 22:34.
edward Guest
14-10-2002, 23:29 Subject: LMM: What is LMM? Explanation & Meaning |
I think so, because, as far as I know, the 'B' only indicates a change in the part number within the VW parts system, and not a change in the component itself.
Translated on 26-10-2026, 22:35.
Bertil Profi-Schrauber
15-10-2002, 6:20 Subject: Part Number: Find Your Item's Number |
The index letter may potentially lead to significant changes, even incompatibility. Perhaps the index letter "B" simply indicates that the supplier has changed.
Okay, gib mir den deutschen Text.
The 13-pin electrical kit for the trailer hitch on the Golf III has the index "A". The wiring harness for the Golf IV has the same number but the index letter "B"! Since the rear light connectors on the G4 and the G3 are anything but the same, these electrical kits are not interchangeable.
So, please be careful when you see the same numbers with different index letters. In this specific case, however, I'm only assuming a change in supplier. Gruß Bertil
Translated on 26-10-2026, 22:36.
Varianti Guest
15-10-2002, 6:49 Subject: LMM: What is LMM? Explanation & Meaning |
The LMM (mass airflow sensor) with the code 'B' was installed in the following Volkswagen vehicles:
Passat 01-02, engines: AVF, AWX.
Passat Synchro 01-02 AVF, AWX
Transporter 1999-2002: AHY, AXG.
The LMM without the 'B' was installed in quite a few models (I don't feel like listing them all right now, but the VW Vento 1Z was one of them).
I would try it if it fits. Surely nothing can go wrong, right?
Translated on 26-10-2026, 22:37.
Ventoman Guest
15-10-2002, 17:25 Subject: LMM: What is LMM? Explanation & Meaning |
Hi!
Okay, then I'll go ahead and buy it.
Hopefully, it will also fit with the air filter housing.
Thank you for the answers.
Translated on 26-10-2026, 22:38.
