Hi there,
A few months ago, I bought a "P-box" (from P-Box.at) *g* on eBay for my Seat Toledo 110 HP TDI with an ASV engine... It's working wonderfully since I adjusted the box.
"However, I have a problem: when I drive at full throttle on the highway for a while, my engine goes into limp mode, and I have to turn it off and restart it. Then it works normally again (usually after 2-3 minutes, depending on the weather and temperature, I think - when driving at full throttle). When the diagnostic computer is connected at my car dealership, it shows: 'implausible boost pressure signal'."
Do I need to adjust the chip further, even though it only causes problems outside of the highway when under full load, or can I solve the problem in some other way??
It would be great if someone had a tip.
