Hansi wrote: |
| ...Could pressure possibly leak out through the electric nozzles/seals during the pressure test? |
Not really...
Does the compression pressure tester work correctly, and is its check valve located as close as possible to the glow plug opening on the combustion chamber side of the cylinder head?
The volume between the glow plug opening in the combustion chamber and the check valve of the tester must be as small as possible.
