Jürgen Guest
21-06-2004, 17:09 Subject: T4 Injectors: Buy Online & Save! |
Hello everyone,
Does anyone have any idea where the 216 injectors are used (in T4 engines with 75kW or 111kW)?
'both?). The background is that I have a 75kW T4 model year 2000 sitting there, from...'
I'd like to remove the injectors to test them, possibly in a Passat AFN/automatic.
to test it on my wife. I'd be curious to see how the car performs.
According to VW-Erwin, the opening pressure of the injectors is the same for both power outputs!
Ich habe versucht in den Bosch-Online Ersatzteilkatalog reinzukommen. Previously.
It worked perfectly before, but for some reason, it's not working anymore.
Translated on 29-08-2026, 0:25.
Joined: 04/12/2002 Posts: 18087 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
21-06-2004, 17:55 Subject: T4 Injectors: Buy Online & Save! |
Hi, in my opinion, only in the 111 kW version...
Translated on 29-08-2026, 0:26.
Profile PM WWW Garage |
dieselcruiser Guest
27-10-2005, 20:16 Subject: T4 Injectors: Buy Online & Save! |
Does anyone know what the orifice diameter of the injectors is for the 75kW T4 engine (ACV)?
Translated on 29-08-2026, 0:27.
Rudi Guest
27-10-2005, 20:38 Subject: T4 Injectors: Buy Online & Save! |
It is in the order of 1Z.
The AFN engine produces a healthy 90 horsepower (although it might produce a bit more soot...).
Rudi
dieselcruiser Guest
27-10-2005, 21:27 Subject: T4 Injectors: Buy Online & Save! |
And what about the injectors for the 103kW Audi A6 TDI (AEL)?
JanT3TDi Blaumann
Joined: 07/07/2005 Posts: 34 Karma: +2 / -2 Location: Lübeck
01-11-2005, 10:16 Subject: T4 Injectors: Buy Online & Save! |
I'm not 100% sure, but are these 0.216-inch valves for a 5-cylinder engine?! T3 Multivan mit 1Z aus '95er Passat + Chip, 3H Getriebe + langer 5ter Gang
Translated on 29-08-2026, 0:28.
