Transponder Programming: WFS 3 Key Learning
Matthias.H
Post11-11-2005, 22:47    Subject: Transponder Programming: WFS 3 Key Learning Quote
I would like to have a key made for a VW Polo (year 2000) and then program it using VAG-Com. The vehicle already has the third-generation immobilizer. Since replacement keys from VW are relatively expensive, I've come up with the following idea: The transponder is only inserted into the key with the light. You can purchase a cheaper key with the transponders for the third-generation immobilizer from various online auction sites. The shape of the key can be replicated using a standard blank. Then, the transponder is attached to the replicated key.
Okay, now let's get to the main issue: To program the key, I need the numbers from the VW dealer. Are these numbers transponder-specific, or can I use a valid number to program any transponder to the car?
Thank you in advance for your efforts.
Matthias Hugel.
Translated on 20-10-2026, 2:39.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 Key Programming: How-To Guide On-Board Diagnostics (OBD)
No new posts Pairing key VW Crafter On-Board Diagnostics (OBD)
No new posts VW Polo 6N: Key Programming Guide On-Board Diagnostics (OBD)
No new posts Passat 3c key programming On-Board Diagnostics (OBD)
