Turbolader umgebaut....Problem ! | Posts 16+
Go to page: Previous  1, 2
Marzocchi
Post11-10-2005, 12:21    Subject: Quote
Okay, just so you know, I now understand what the problem is. Attached to the flange of my turbocharger is usually a type of silencer that's part of the turbocharger assembly and isn't available separately. The only solutions are either to machine your own flange or to install a compressor housing from a GT1749VB with part number xxx016G. I'm going to try the latter now...
Golf IV - ALH - Erstzulassung 9/99
Translated on 13-08-2026, 5:23.
Thomas
Post09-11-2005, 22:23    Subject: Quote
Hello Marzocchi,
Has anything developed in the meantime? Have you found a different compressor housing or managed to modify a flange?
Greetings,
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
Translated on 13-08-2026, 5:24.
Marzocchi
Post10-11-2005, 0:49    Subject: Quote
Okay, so I just installed a compressor housing from a 016G turbocharger. It seems to be working well so far. However, I'm still experiencing the rattling noise at full boost pressure (which is why I actually replaced the turbo in the first place). Does anyone here have any ideas about where this rattling could be coming from, specifically when it only occurs at full boost pressure, and if it's not related to the turbo itself?
Post10-11-2005, 9:08    Subject: Quote
Marzocchi wrote:
However, I still hear the rattling noise at full boost pressure (which is why I actually replaced the turbo in the first place). Does anyone here have an idea where this rattling sound, which only occurs at full boost pressure, could be coming from - if it's not the turbo itself?
Perhaps something like this?
/viewtopic.php?t=6954&highlight=kaudern
Translated on 13-08-2026, 5:25.
Marzocchi
Post10-11-2005, 10:54    Subject: Quote
Thank you for the link, Ulf.
But that's probably not my problem.
"The rattling noise doesn't occur when I release the accelerator. It's independent of engine speed. I can pinpoint the rattling directly to the LDA (Linear Differential Actuator). It starts very quietly at 0.8 bar, is clearly noticeable as a background noise at 1 bar, and becomes quite dominant at 1.35 bar (I don't use any more pressure). As the pressure decreases, the noise also gets quieter – until it disappears completely below 0.8 bar."
It can't actually be the turbocharger; I replaced it as I mentioned, and the rattling noise is still exactly the same.
It's subjective, but it seems to be coming from the direction of the glove compartment.
Translated on 13-08-2026, 5:27.
Thomas
Post10-11-2005, 12:01    Subject: Quote
Besides the possibility that it could be any part that has come loose, could you check how much space there is between your exhaust pipe (the pipe between the catalytic converter and the turbo) and the underbody/splash guard? In my case, the pipe was lightly touching the tunnel plate, which also caused a rattling sound. But as I said, it could be anything from a nut that fell behind the glove compartment to a loose heat shield.
Since it's not dependent on engine speed, but rather on load – and therefore boost pressure –...
Could it be that the increasing engine rocking motion is causing more noise?
Have you found or created an ATL support structure? This has acoustic reasons as well.
Thomas.
Translated on 13-08-2026, 5:29.
Marzocchi
Post10-11-2005, 13:58    Subject: Quote
Hello, hmm, I guess I'll have to start looking again.
What is an ATL support?
Translated on 13-08-2026, 5:30.
Post10-11-2005, 15:28    Subject: Quote
Exhaust fumes.
Turbo.
Charger.
Support.
Translated on 13-08-2026, 5:31.
Marzocchi
Post10-11-2005, 18:12    Subject: Quote
Ui. Gibt es etwa keine passende Stütze im VW Programm ? Ich habe nämlich keine gefunden - dabei muss sie ja eigentlich existieren. Ich habe die normale Stütze drangemacht und mir einen WInkel angefertig tmit dem ich sie dann am original gewinde festgeschraubt habe. HäAccording to bombig.
I actually just solved my problem, and I'm very happy icon_biggrin.gif.
"I made two changes. First, I properly reattached the headlight cable that was loose and touching the plastic turbocharger boost pipe. Second, I patched up the small hole (which I had previously drilled to take a pressure reading for the LDA) in the 90-degree bend hose just before the EGR valve."
I think it was the cable though... Anyway, there's no more rattling now. I didn't expect the plastic pipe to vibrate so much at high boost pressure, but I guess it has to, otherwise it would make noise...
Translated on 13-08-2026, 5:32.
Devilseye503
Post10-11-2005, 20:08    Subject: Quote
I think it was more likely the hole – I also had a faulty charge air cooler recently where there was a small leak. The noise was a slight rattling sound at higher boost pressures. After replacing it, the problem was definitely gone.
Translated on 13-08-2026, 5:33.
Marzocchi
Post11-11-2005, 10:54    Subject: Quote
Hello, it turns out the problem was a small hole in the pressure hose. Yesterday, while on the highway, the BW tape came loose again (it got too hot), and the rattling noise is back. Does anyone know how to fix a needle-sized hole in the 90-degree bend without having to buy a whole new €40 hose?
Translated on 13-08-2026, 5:34.
mserge
Post15-11-2005, 16:05    Subject: Quote
@MarzocchiViewing profile: Marzocchi
"The inner tube has a puncture. Clean it, then apply the adhesive patch from the repair kit to the inside of the tube and vulcanize it in place. Since you know there's significant pressure buildup in that hose, you should try this method. Otherwise, you might have to replace the entire hose. If even that doesn't hold, you'll need to replace it."
Maybe it will also work if you stick your tape on from the inside?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Marzocchi
Post15-11-2005, 16:25    Subject: Quote
Hi, I've already tried patching the bicycle tire from the outside, but unfortunately, it didn't hold. It would technically be possible to do it from the inside, but I'm worried that it might come loose. If the patch is forced into the motor with 1.5 bar (there's not much left after the pipe except for the AGR...), I doubt it will go down easily...
Translated on 13-08-2026, 5:35.
vagtuning
Post15-11-2005, 16:34    Subject: Quote
He probably won't be happy about it; he's bound to get indigestion from it.
Translated on 13-08-2026, 5:36.
mserge
Post15-11-2005, 17:34    Subject: Quote
If it doesn't hold, you'll probably have to pay the €40 and put a new one on. Then nothing can go wrong. "Basteln" is always tinkering/building things.
Then you learned for 40€ that you shouldn't poke a hole in a hose like that icon_wink.gif.
No offense! / No hard feelings!
Translated on 13-08-2026, 5:37.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Turbocharger Whistle: Documentary Analysis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf 2 TDI Conversion: Photos & Details Upload
No new posts Fixed Issue, New Problem Arises Diesel Engine Technology
No new posts Turbocharger for Audi A6 Diesel Engine Technology
No new posts ASV Turbocharger Diesel Engine Technology
