MSG: The Unknown Message
Styrian
Post02-12-2005, 9:51    Subject: MSG: The Unknown Message Quote
After I intended to use VAG-COM to log data (see https://community.dieselschrauber.org/en/viewtopic.php?t=10936), I unfortunately didn't get very far. I'm missing the label files for my MSG... and this MSG doesn't recognize the latest version of VAG-COM either. It's the MSG 038 906 013 AB. In principle, there's also no MKB (engine code) like mine (AQM) except for one engine type (which certainly isn't mine). Can someone provide me with information about the measurement blocks (MWB) of this control unit, or even better, the label file for it (or at least explain which one would be approximately the same)?
Greetings, Sytrian.
Translated on 01-09-2026, 20:11.
Rudi
Post02-12-2005, 10:32    Subject: MSG: The Unknown Message Quote
The hardware is identical to that of the 038 906 018 xx TDIs (MSA15.7).
Since the label files for all TDIs are not drastically different, you should...
You can find the temperatures in MWB 7.
Rudi
Translated on 01-09-2026, 20:12.
Post02-12-2005, 10:54    Subject: MSG: The Unknown Message Quote
Is AQM not an SDI?
Translated on 01-09-2026, 20:13.
Styrian
Post02-12-2005, 10:58    Subject: MSG: The Unknown Message Quote
...yes...it's an SDi...
Best regards, Styrian.
Rudi
Post02-12-2005, 11:22    Subject: MSG: The Unknown Message Quote
Sure, SDI.
The measurement blocks are still the same!
Anything related to turbocharger pressure in TDI engines is either hidden or ignored.
Rudi
Styrian
Post03-12-2005, 17:11    Subject: MSG: The Unknown Message Quote
Okay, I'll get started when the outside temperature is a bit milder...
Translated on 01-09-2026, 20:14.
